Results 1 to 14 of 14
Thread: Problems when buying a vh?
    vh
    Dec 2009
    Default Problems when buying a vh?
    To all of you with experience in owning a vh and because they are so old, what general problems and set backs have you had in modding your cars?
    Cheers Ben
    vs 5L ute and vh project
    Evel Cownievel Champion!
    Dec 2008
    NSW inverell
    vh
    Dec 2009
    fair enough also as im only 19 i can't get a v8, well i can but I might get busted, do they attract much police attention?
    Dec 2008
    NSW inverell
    hahahah funni story i just got my licence back got cought driving a v8 on my ps, 7 points for driving a high performance vehicle and 2 for no p lates and lost it for 3 mths lol just half 2 wait 3 mths for my blacks now lol
    vh
    Dec 2009
    oh no that sucks what state ru in? and how do they determine if its a high performance vehicle?
    Im sure there are people driving around with routed v8's that struggle to get from a to b
    Dec 2008
    NSW inverell
    Im in NSW no v8,turbos,supercharges except if its desiel thats y i think it should b power 2 weight
    vh
    Dec 2009
    yer we have similar rules here but I'm not sure what happens if we get caught with a v8, I've heard its just a warning. I'm stuck in a dilemma I want a vh so bad, i don't know why I am so fond of these cars but every time i see one i just feel something and I think i have to just have one of them. the sound the look its just too much for me, I'm overwhelmed lol, kind of like an ex gf that I can't get over lol. But to get a good one they are all v8's.
    On the other had i could get a vz but i don't have the passion I've always had for the early girls, I just don't know what to do anymore.
    Go with my heart or with my head? I fear that I'll never be satisfied until I own a Vh
    VH SS
    May 2009
    Toowoomba, Qld
    the VH was the third revision of the first gen body shell, so a lot of the problems had been ironed out.
    Keep in mind the VH is approaching 30 years old, so age will take it's toll on cars that haven't been restored.
    Rust - common places are under the front and rear windscreen seals. Not always detectable, but often you can feel lumps in the windscreen rubbers if you run your fingers over them. Chances are there is going to be at least some rust under the screens, unless it's already been repaired. They also like to rust behind the bottom of the rear wheel arches. Mud gets caught up in the corner of the gaurds and rusts out. Also pay attention the sills, if the water drains are blocked the sills will also rust. Have a good look at the boot floor and the tail light panel (inside boot). Leaking tail lights that aren't rectified allow water into these areas and often rust bad if neglected. Rust can also occur in the area behind the kickpanel. Leaking windscreen runs water into these areas, usually you will only notice the rust if you remove a front gaurd - but can be seen if you look hard enough.
    Wiring can also be a source of problems, but not something that can't be repaired. Main connector in the engine bay (near the firewall drivers side) tends to melt causing loss of power to the entire car. Usually the best fix is to cut the connector out and solder the wires. Crappy ceramic fuses under dash can also cause headaches. I'm planning on converting the fuse box to blade fuses
    If the car has been dumped on it's guts, riding bump stops etc for too long, sometimes the weld where the quarter panel meets the roof, can crack - crack/s in the paint around that area are a giveaway.
    Suspension bushes are usually stuffed if they haven't already been replaced. Can make the car an absolute dog to drive if the bushes are flogged out. However, not an overly expensive exercise to replace. Also check the strut top rubbers. Also check the upper bearing on the steering column (check for vertical & lateral movement in steering wheel)
    The blue motors were good engines. No real issues with them, apart from usual wear & tear, oil leaks. Trimatics are usually trouble free. The M20 & M21 manual gearboxes are rather fragile - particularly behind the V8's. Check for crunching gears, excessive noise etc.
    Check tailshaft centre support rubber, they usually crack with age.
    Not many parts are available from Holden these days, so you are going to have to rely on second hand bits from wreckers, aftermarket bits from the likes of e-bay, repco & rare spares. The majority of parts are still available if you are willing to look around - just be prepared to pay inflated prices for some parts - especially NOS parts.
    Overall these cars have held up well for their age, whilst there are a lot of neglected examples around - I do often see some well looked after VH's for sale. If you plan on going down the V8 path, don't overlook a good condition VH 6cyl. The conversion to a V8 is very easy, much easier than repairing a V8 VH full of rust etc
    Probably going to need to spend some time & money on a VH (unless you buy one already restored). But they are well worth the effort IMO. Great classic Commodore look, not too big, not too small. A feather weight at around 1300kg! I'd never get rid of mine - love it too much.
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Quote Originally Posted by smi5575 View Post
    dude.. thats deep.
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    VH SL/E 5.0
    Nov 2009
    Go with the VH. They are a great old bus, the last of the chrome bumbers. I have owned three VH's over the last 18 years or so and never had a major problem. I drove to Queensland and back twice in two of them and they never let me down. Darren_L pretty much summed any issues you may experience but all in all I'd say pretty minor compared to what can go wrong with modern cars, but then I'm a little biased!...
    I will add however, if you do go with a VH try and get one with low K's - they are around I see then all the time in the trading post / car sales. One that has been garaged and serviced all it's life by the same elderly owner....
    vh
    Dec 2009
    Thanks for the advice darren I have read about your Vh before and you gave me some advice on a vh I almost bought a while back in December.
    I was planning on buying one that has already had a fair bit of cash spent on it so I wont have to worry about getting it roadworthy first and hopefully all the running gear all in good order.
    I was considering the option of doing a injected v6 conversion. Does anyone know what is involved a job like this? I have read about people having to change their brake booster and master cylinder?
    Also do I have to change the K frame (not 100% sure what this is) and fuel tank? And if so why?
    also I'm in no rush and I'm open to new ideas so feel free to speak what you think, any advice is appreciated
    thanks again
    VH SS
    May 2009
    Toowoomba, Qld
    my pleasure mate
    V6 conversion is fairly easy.
    Yes you need a crossmember/k-frame out of a V6 Commodore. It bolts straight up.
    Yes you will need an EFI fuel tank (they have a swirl pot inside). Easiest swap is a VL 6 cylinder tank
    There are conversion wiring harnesses available from the likes of www.caenterprises.com.au - EFI Conversions
    And no you don't need to change the brake booster & master cylinder - they are essentially the same as the VH. I'd recommend using a 1 inch master cylinder though if the VH doesn't already have one fitted and you'll need rear disc brakes fitted
    vh
    Dec 2009
    Thanks darren your advice is very helpful and I still have a lot of thinking and planning before I decide what I want to do.
    Because I am so young I sometimes feel like I am over my head, in modifying car world, that's why I really appreciate your advice, cheers.
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    Check the floor pan around the seat rail mountings as well and make sure it has no cracks.
    Best bet is to chuck it on a hoist before buying and have it inspected.
  1. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  2. Buying New Old Tyres? - Problems?
    By sweefu in forum General
    Last Post: 31-01-2010, 03:39 PM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. buying a vs ute, common problems?
    By bognog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 08:43 PM
  5. Problems To Look For When Buying A VP Commodore
    By Dr_Hoon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2004, 08:41 PM
