Results 1 to 5 of 5
Thread: temp gauge?
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Default temp gauge?
    my temp gauge doesnt work scince i brought it,
    it used to just sit on cold then it floated about
    now scince i turn it on the gauge will go past hot and out of visibily in under 1min
    like not even 30 seconds
    any one know how to fix it?
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    VK C'dore GTS 3.3ei
    Sep 2005
    I'd check out the temp sender first, could be a faulty sender or poor earthing of the sender.
    vk.jonno's Avatar
    Nov 2009
    south east
    well i checked that and all there was was the brass knob but that was it no tube/wrie coming off it or anything????????
    yer that is probly the problem, could this be messing with my comp making it think its allwase cold or allwase hot or something??????
    what do i do to fix it? (get new wireing for it obviously) but how and shit :|
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    The wire will be there..... somewhere. and if your gauge is going right off it would most likely be that it is earthing out somewhere, and if you find that its not at the end it could be broken somewhere further in and earthing there. But the gauge could also be stuffed.
    VK C'dore GTS 3.3ei
    Sep 2005
    Yep hunt down that wire on the loom near the sender. Clean the end of wire tag and remove an re-install sender to re-earth (watch for hot coolant, plug with rag while you do it)
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. temp gauge an fuel gauge not working
    By nathan_867 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2010, 10:55 PM
  3. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  4. V8 temp gauge
    By twinturbo5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-12-2008, 11:21 AM
  5. Temp Gauge !!!!?
    By Turbo_dreams in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2006, 01:14 AM
