Results 1 to 17 of 17
Thread: 290mm front rotors - Caliper Options
    VK C'dore GTS 3.3ei
    Sep 2005
    Default 290mm front rotors - Caliper Options
    Hi All,
    Just put 290mm curved slotted rotors on the front of my VK with standard VN V8 single pot caliper. See pic. Didn't realise that the V8 VN caliper uses the same brake pad as VK 270mm rotor. This means there is a lot of unused brake surface on the inside of the rotor. Perhaps a standard VN rotor is 290mm but the brake area is not as wide as these aftermarket rotors?
    Are there any other caliper options with 290mm rotors that use bigger pads? Twin pot?
    Thanks.
    Attached Thumbnails Attached Thumbnails 290mm front rotors - Caliper Options-vk-jc-3.jpg
    VS Calais & vh sl
    Dec 2006
    deception bay
    vt calipers use more but should be on 296mm discs so they may be a bit big. are you sure you have the v8 caliper not the v6?
    efi 202 torana, vk project car!
    Mar 2010
    mount gambier sa!
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Quote Originally Posted by 180sc View Post
    Yeah the v8 calipers were the finned ones, same as in his pic above. I think the VL turbo's and V8's had the same as well. I know when ya put them calipers on older cars ya have to change the rotor as well as the v8's had bigger rotors which suited the finned calipers......not sure on sizes tho.
    If ur worried about ya brakes tho, best thing to do is to upgrade to vt brakes.
    VK C'dore GTS 3.3ei
    Sep 2005
    Not really worried about the brakes, performance is fine, even with drums out back. It's more the look...
    Yes VT adaptors hubs and rotors etc are the way to go. Just gives heaps more options. It seems it pays to upgrade the booster and master cylinder as well due to the greater volumes of brake fluid being pushed around. I'll be going to rear discs at some stage too.
    What brakes did the VN SV500 have?
    sam5l is offline australias driving future
    vk calais 5L / vn spak buick powered
    Mar 2010
    reynella,SA
    vn grpa had 330mm twin pot ve omega kit is about 750 with braided lines 322mm twin pot thats the way im going did the vlt upgrade improved but not enough for my liking
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Dont forget when picking calipers you not only need to check the diameter but rotor thickness, the VT rotors are thicker as well.
    If you want to keep your existing rotors check out volvo, nissan skyline & 300zx calipers you might find something suitable for your size rotor.
    I run VZ Twin spots on the front and VZ ventilated discs and calipers on the rear
    And yes it stands on its nose
    cheers
    Scott
    Attached Thumbnails Attached Thumbnails 290mm front rotors - Caliper Options-smimgp2512.jpg   290mm front rotors - Caliper Options-smimgp2501.jpg
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    330mm Group A twin pots ftw!
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    DANNY8's Avatar
    Apr 2004
    Here's some pics I took during the process of chucking our VT brakes on our dirt circuit car. I can't believe how easy it was. Could prolly do it in half hour if ya get into it. We got our kit for $400.
    Old brakes.
    New seal and bearing on all greased up.
    Hub adapter on.
    All done!
    Old rotor with new rotor.
    Old caliper with new caliper.
    VX 383 turbo & VK Royale LS1
    Apr 2009
    South Auckland
    Damn thats cheap !!
    How did you get on with hoses ?
    where did you get the kit from ? I just need some hub adapters at a reasonable price ....
    Quote Originally Posted by DANNY8 View Post
    Old brakes.
    Hub adapter on.
    All done!
    VX M6 ....... 464rwkws of turbocharged fun.
    VK LS1 in the build..............
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by RED1M8 View Post
    Damn thats cheap !!
    The hoses come with it. I actually got them 2nd hand. The guy who bought them new, put them on his VL, then ended up scrapping the VL I think so he pulled the brakes off and I bought them. The only use they had was pushing the car around, don't think the car had even been driven with them on. So yeah when I saw them for sale I couldn't say no. Was the whole kit, rotors, PBR calipers, hub adapters, bearings and rubber lines.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    So the kit you bought is an after market VT spec Rotor and caliper which bolt straight on with the adapter hub?
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by VK SL 202 View Post
    Yep. Took the old calipers and hubs off, removed the bearings and cleaned the old grease off. New bearings went on, with new grease and the hub adapters. Rotors went onto the hub adapters, then the calipers went on, bolted to the original calipers mounts, chucked the pads in, tightened everything up, then chucked the rubber line on to replace the old one, which connected up no worries. Bled them, then she was all ready to go.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I had no idea it was that easy, just another quick question. Whats the go with the brake hose, is it a custom made one or VT one?
  15. #15
    DANNY8's Avatar
    Apr 2004
    Yeah custom lines I presume. Just go visit a brake or hydraulic shop and they should be able to help ya. Brake shops might have them in stock already, hydraulic shops should be able to make them. Maybe take a VT line and one similar to ur own in, so they know wat ya need.
  16. #16
    VK SL 5spd
    Sep 2009
    Wagga Wagga
  17. #17
    VZ AWD One Tonner
    Jul 2006
    In early model Commodores you're far better off going to a VE caliper kit like this:
    VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
    than the VT ones because it won't require a change of master cylinder, because the VE pistons are more appropriately sized. They're also a better caliper, with less flex than the notoriously bad VT ones.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. Project Mu High Performance Disc Pads, Rotors and Caliper Kits!
    By gslrallysport in forum GSL RallySport
    Last Post: 05-08-2011, 08:49 PM
  2. [VIC] Vt-VZ rear caliper and rotors.
    By vr_owner in forum Parts And Other Items For Sale
    Last Post: 10-10-2009, 05:55 AM
  3. [QLD] (FS) DBA GOLD Slotted/Drilled Front Rotors & Rear Standard Rotors
    By markc3012 in forum Parts And Other Items For Sale
    Last Post: 26-09-2009, 10:44 AM
  4. [WA] WTB: VN rotors, 290mm fronts suit VN
    By savage1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 01-04-2009, 11:21 PM
  5. WTB: VS Front ABS Caliper and Slides
    By I wish I was a Cab Driver in forum Parts And Other Items For Sale
    Last Post: 20-09-2004, 05:20 PM
