hey just wondering whats the biggest alternator i can get on the VH 202 i believe right now its got the 55amp i was hoping to get a 100amp but dont want the single wire, still want it so the Battery warning light show's up and all that and one that is a pretty much direct bolt on no stuffing around also where would i get it from.
thanks heaps Nath
If it weren't for my lawyer, I'd still be in prison. It went a lot faster with two people digging
soz bro, the only 100A's have a different pulley. serpintine i think its called, we have a V pulley. V8 alternators are 60A from factory. you can get an auto elec to chang the regualtor and install an exciter module for around 200 bucks which will bring a V8 one up to around 80A.
lol why bother.... couldn ya wire up somethin to like a second had vt one so ya battery light comes on? n it aint too hard to change the pulley just gotta rind the right one. or get one machined.
hmmm seems like to much fkn around to be honest, just worried with the new mono block 1600watt amp running the 2subs might not charge the battery like its ment too but ill see how things pan out and play it by year.
one amp will be fine with a 55A. its when you start adding electric fuel pumps and thermo fans you will run into problems.
your amp will only be fused for 10 or 15A anyway. shouldnt ever use that much. lights are around 20A on full beam, heater is 15A and wipers are 15A so with everything going sitting in traffic (at idle) you might start running on battery power, but thats ok for a little while.
yeh might jst check the charge with the multimeter while i got everything on and see how its going thanks heaps
multimeter will only tell you it has 14.5V, wont tell you the current draw. the only way to tell is disconnect the negative terminal off the battery while its running and turn your radio on full crank
get the regulator in the alt changed to a bigger one and put a bigger pully
trip the the auto sparky they can do anything from 50-500amp in a single alternator LOL most of the so called one wire ones still have the charge light
