lol i know there is like a cerclip thingy in there, but who has a good way of gettin it off without the special tool?
and the reason im doin it is the rear left inside door handle doesnt work, should just be somethin come apart but anyone know how it all goes together? :P im doing pre research before i pull it apart then get frustrated cos it aint doin what i want it to. still yet to get that dam original tape deck out! grr
I have used multi tool pliers and scissors b4 to get cerclip off only thing i could get down there lol
Just use a rag, it will catch on the end of the clip and pull it out, easy 2 second job
yeah ive always used a rag in removing them,works good
I use a rag. Hard to explain, but run it around behind the winder and it normally catches the circlip and gets it off pretty quick.
As for fixing ur door not opening. The best thing to do is prolly take the trim off the other side as well so ya can see how a working door works, then look at the dodgy one and see wat's goin on.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
lol see this is why i love this site! all these little ways of doing things better! and yea il take the other door trim off and have a look! cheers guys! still tryin to get the dam tape deck out! help?
you will have to take the facia off, so from memory all the trims up to the steering column need to come out. then after its off you can get to the back of it.
either that or there are two little slots in either side of the radio that you stick thin bits of steel into, which 'un-catches' the locks in the sides of the unit and itll slide out.
