Results 1 to 7 of 7
Thread: Scheel seats?
    VT Berlina S2 5.7
    Mar 2009
    Default Scheel seats?
    I have a VK.
    Just wondering if the scheel seats from an ESP Ford are the same as the Brock VK's,
    or can I only use the VK Brock seats?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    same same, also found in some escorts and even ambulances.
    cheers
    Scott
    VT Calais S1, VK Wagon EFI 5.0L
    Jul 2005
    Just need to change the rails over to Commodore ones. There are a few slight differences between some of them, but mainly the foam. Most people wouldnt be able to pick the difference.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Same but the HDT versions had minor padding and headrests changes.
    VT Berlina S2 5.7
    Mar 2009
    Appreciate the help fellas.
    Thanks.
    Just to make sure, so any Scheel seat (Rs200,ESP..ambulance) can have their rails swapped out with VK rails with no mods done to base?
    Will they bolt up properly?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Thats correct heres a pic of the underside of my drivers seat there are basically 4 bolt holes on the underside you bolt your rails to.
    If the worst happens and yours dont fit measure them up and drill new holes, I guess you would only need to drill 2 holes worst case as you could/should be able to use 2 existing holes.
    cheers
    Scott
    VT Berlina S2 5.7
    Mar 2009
    Thank you very much vkberlina!
  1. Rear Seats QLD LAW + Interchangeable Seats
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-03-2009, 08:30 PM
  2. WTB: VR/S Calais/Berlina Seats or VT Seats.
    By Grennan in forum Swap / Wanted to Buy / Trade
    Last Post: 06-07-2008, 05:36 PM
  3. VIC Sports bucket seats (like racing seats)
    By ucwepn in forum Parts And Other Items For Sale
    Last Post: 23-12-2005, 03:17 PM
