Results 1 to 5 of 5
Thread: anyone know much about the ecotec v6 conversion for VH
    VH SL 202
    Feb 2010
    Default anyone know much about the ecotec v6 conversion for VH
    hey everyone i have a v6 and my brother wants to put it in a vh and i need to know how much for the k frame and all the other bits to get it in and running need help asap
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Quote Originally Posted by SabbathSS View Post
    i believe he is asking for prices
    mate if u only have the motor ur not gona get far..
    and itll cost u more in the long run
    u needa get a complete donor car really..
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    VC
    Oct 2008
    About $50 for a K frame. $185 for a gearbox crossmember. $375 for a wiring harness adaptor. $377 for a tailshaft made up of a VL &VN unit with new uni joints and centre bearing all fully balanced. V8 radiator so the outlets are in the right place, at least for a VN don't know about ecotech. The small Salisbury will probably break. You should also upgrade the brakes. I don't know about needing a donor car, I just put a V6 VN into a VC and used very little from the VN and I didn't have a wreck in the backyard that I had to dispose of. Use a power steering rack from a VL or VN with appropriate intermediate shaft. I used a VL column complete. it's cheaper than replacing the pump with an idler pulley. The cheapest way to set up the fuel system is to replace the tank with one from a VL as it has the internal lift pump and I then used an upgrade Pierburg EFI pump. To do it properly is not cheap. PM me if you want more details on prices etc.
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Well, depends on how lucky you can get...
    My girlfriend paid $220, for a complete running VP, and have stripped it bare. The shell is at the scrap yard, leaving us with all the panels, and all the interior to sell off to make some money back for it all.
    We're using the front crossmember, engine, gearbox, wiring harness, LSD diff, brake booster / master cylinder, all suspension, brakes, tail shaft - (either need half of a VL one, or shorten this one for $150) fuel tank, and fuel lines.
    And also putting the VP dash into the VH, something different.
    If the steering column fits, that too
    And the bonnet struts
    Theres probly more, but thats all I can come up with atm, and well you get the idea.
    We're half way through doing it so there may be something else we might need/use of the VP still.
    IMO if you're going to do it, its cheaper to buy a donor car, as already suggested - if we were to buy all that seperately it'd cost an arm and a leg...
  1. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  2. vl ecotec conversion
    By Panama in forum V6 Development And Modification
    Last Post: 30-10-2008, 06:38 PM
  3. vr ecotec conversion
    By benny mckellar in forum General Discussion
    Last Post: 19-03-2008, 04:51 PM
  4. VS- Later Ecotec conversion
    By GTP 85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2007, 10:36 PM
  5. Ecotec Conversion
    By Sound Wagon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-09-2005, 11:44 PM
