Results 1 to 3 of 3
Thread: Fitting more moden compnets into your 1st gen?
    vh
    Dec 2009
    Default Fitting more moden compnets into your 1st gen?
    Is it hard to fit more modern components into your 1st gen like, electric windows, traction control and cruise control?
    Thats all of that I can think of at the moment but if you can think of anything else let me know.
    And if you know how to do any of these things let me know
    thanks
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    cruise and electric windows is easy cos' they came out with both.
    TRC would be a good one, need wheels speed sensors on each wheel that the TRC would operate on plus the module to control it, so i guess you could just do the two back wheels. bit if you were going to go to that extent, you should put a sensor on each wheel, get an ABS controller and pump and stick ABS on it as well.
    then all you need to do is stick an airbag shock sensor in under you center console and stick a late model steering wheel on, maybe some curtain airbags in the pillars, side intrusion protection wouldnt go amiss either while your at it. why not, its just a couple of big steel bars.
    hell, scrap the running gear off a R32 GTR and make it AWD, in fact... i think we just described a GTR didnt we?
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    But ari, if you fit airbags (Not the suspension) dont they have to crash and test the car to make sure it will work in a crash and not fire when cruising?
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  1. Fitting 6.5' to VT?
    By ascension24 in forum Car Audio
    Last Post: 28-06-2009, 10:42 PM
  2. Rim fitting
    By rudd7454 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-12-2008, 06:29 PM
  3. Fitting a TOW BAR
    By XXFR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-04-2008, 09:00 PM
  4. Fitting a kit
    By 2_SeeK_U in forum General
    Last Post: 16-02-2005, 10:57 AM
  5. Fitting ABS
    By HQ_Kid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2005, 10:46 AM
