Results 1 to 3 of 3
Thread: Starter motor keeps clicking over when ignition off
    bang_chong is offline hmm new project
    Vk Executive
    Feb 2010
    gold coast
    Default Starter motor keeps clicking over when ignition off
    Hi guys I got myself a Carbied 202 powered VK. Well I put a second hand battery in it and after a week I went to start it and when i turned the ignition off the starter motor kept trying to start so to stop it I had to take the ground off the battery. I bought another 2nd hand battery and it was fine. It was fine for about 4 weekends after that when I worked on it but when I left it for 3weeks it had the same problem. Has anyone had this problem or know what might be wrong? Im just afraid to buy a brand new battery and for it to do this problem again.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    It would be a wiring problem, could be any where but most likely you have a wire rubbed through somewhere and its shorting to + power causing the starter to be activated, look along the wires around the battery area to the fuse box, then along the main harness across the back of the engine. Could be a dodgy ignition barrel but i doubt it. If you cant find it just disconnect the little wire from the starter while your driving so it doenst activate and break stuff while your getting to the bottom of the problem.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    sticky starter solinoid give the shaft the cog slides on a grease
  1. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  2. Starter motor/ignition switch/neutral safety switch?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 08:19 PM
  3. VT Starter Motor / Ignition Problems
    By rensvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2008, 02:39 PM
  4. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  5. clicking noise front of motor VN
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2005, 08:56 PM
