Results 1 to 4 of 4
Thread: New car problems
    VH SLE 308
    May 2010
    Default New car problems
    Just bought a VH SLE and have a few issues. Fuel guage does not work and wondering if there is a common issue or easy fix? dash lights are dull and so are headlights is this just a bulb replacement or possible earthing issue? And a T5 manual from a VN has been put in, would a custom speedo cable need to be made or can the VN cable be used as the speedo does not work
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Im thinking custom, as Vn use a speedo sensor. though i did read on here somewhere of someone using a falcon one. or something along the lines of a falcon modified one. What engine does it have? Fuel gauge could be a few things, sensor in the tank could be stuffed, gauge could be stuffed, wiring could be broken but if its rubbed through somewhere and if it earths youll have a full gauge reading. Dash could have dust all over the bulbs but most likely they are just dull from factory, both my VK's are dull, ones a bit better than the other though. Is the glass on the headlights nice and clear and the inside still coated in all its reflective stuff? pull out a bulb and check it, wipe off the glass with a tissue to remove fingerprints and put it in without touching the glass again cause it could create a hotspot if your unlucky.
    VH SLE 308
    May 2010
    It has VH 308 in it. Will have to ask around a bit more about the speedo cable. Will play around with the other issues a little more and see if i can sort them out. Thanks mate
    VH SS
    May 2009
    Toowoomba, Qld
    I used to run a speedo cable in my last VH with the carby V8.
    I just bought a cable to suit from Dellow. But plenty of places make them - Castlemaine Rod Shop sells them too. They aren't overly expensive
    fuel gauge, probably a wiring or sender unit problem. Check the wire is still attached at the fuel tank sender unit.
    Dull dash lights..... I'm afraid is standard on VB-VK. I replaced mine with super bright SMD LED's http://www.ledshoponline.com/automot...board_bulb.htm
    dull headlights - I had the same problem. Crap ceramic fuses usually make bad contact & melt the plastic in the fusebox. I bypassed the ceramic fuse, wired in a blade type fuse instead. Good headlights now. I'm also considering wiring in a headlight relay - something Holden neglected to do on the VB-VH
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  3. vt problems
    By maxwell in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2008, 03:05 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. VN problems
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2005, 12:42 PM
