Results 1 to 7 of 7
Thread: 84 vk 5.0L with play in rear LH wheel i cant get ride of.
    1984 vk commodore 5.0l
    May 2010
    Default 84 vk 5.0L with play in rear LH wheel i cant get ride of.
    I have got play in rear LH wheel, feels just like a wheel bearing. when driving with no load on vehicle i can hear a knocking sound coming from rear LH side. also when you spin the wheel backwards the play goes.
    Work that has been done to try and slove this issue is
    -nothlan bushes right threw rear end
    -wheel bearings replaced with the thicker seals
    -spacers have been tried behind wheel bearings also
    -axles swaped from side to side, play stays on the left side.
    -axles checked in lath for straightness
    -new diff head ( rather a recond diff apparantly)
    - new diff houseing
    i am at a complete loss please help
    sam5l is offline australias driving future
    vk calais 5L / vn spak buick powered
    Mar 2010
    reynella,SA
    do u have an adjustable panhard rod? or maybe the mount is weak or maybe ur dreaming
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Can you physically feel the play when you jack it up off the ground with no wheel on?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I would check shock absorbers & backing plates for the rear brakes that bolt ontot he diff housing. Else as Sam5l said Panhard rod if you jack it up and can see the modement then it should ben easy to solve.
    I had a diff go in my VK once which the bearings for the axels used to float in the housing and give a knocking noise around corners, I ended up swapping the complete diff over.
    chers
    Scott
    VS ute, YZF-R6
    Sep 2005
    Is it a knocking or creaking sound? Can you physically fell anyplay anywhere when its free. (in the air)
    Had the spots weld creaking in the left hand side once but the car was off the road before attempting to fix it. Sounded like a creaking sound coming from the door but it was when going round corners but never under load.
    May 2010
    Thank you all for your help. it turned out the diff head i had fitted, had the same problem. replaced with new diff and issue gone.
    VS ute, YZF-R6
    Sep 2005
    Nice. Hope your not out of pocket for it?
  1. Play in steering wheel.
    By Hytes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2007, 06:56 PM
  2. the worst rear ride height picture
    By andyman in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-01-2007, 04:40 PM
  3. noise from rear right wheel
    By patrix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2005, 05:34 PM
  4. Rear Wheel KW
    By Terence in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2004, 02:00 PM
