Results 1 to 4 of 4
Thread: Black motor 202 carby wont start
    VK Calais
    May 2010
    Default Black motor 202 carby wont start
    So i have a Vk Calais, and it had a red 202 in it for some reason, dont ask? Anyway i got hold of a black motor 202 carby, and me and some mates installed it a few days ago. Now the problem is the motor is not starting, its turning over just getting no spark. We have swapped dizzys/coils/leads and still it will not start. Now yesterday i was looking in the engine bay, and there are 2 black plugs that arent attached to anything. One is coming from it looks to be the transmission and it ends right on the firewall, and the other is coming from the back of the block. Im not sure what these plugs are for and would like some advice from people with more experience than myself. Please help, I just want my car to go already, thanks.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    They would be for EST and it would be why your engine will not start. I think there are magnets on your flywheel and a sensor on the bellhousing so it knows when to fire. This system is a real pain and most people convert to an electronic dizzy off a blue motor.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    mate, if its a stock HEI dizzy then alls you need is ignition + to the coil, neg and pos from the coil to the dizzy and it should fire. if its as tree cutter says and its EST then .. well, yeah. bags more issues
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    If you still have the original loom for EST there will be two wires for the throttle sensor, 1 for the Anti-dieseling solenoid and 1 for the choke. The two little black ones are probably the Throttle sensor switch. All up around the carby/ back of head area. oh and one for the EST Diagnostic mode, thinks its green from memory? What Carby has it got? And as Ari said, only need power to the coil with negative and positive sides of the dizzy connected to run- and fuel of course. Check for spark then make sure its got fuel as the pump wont prime on an empty tank.
    just noticed it is a calais, should have been EFI in that case.
  1. Black 202 Carby - Bye, Bye EST
    By codfishface in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-11-2010, 06:47 PM
  2. wont start, starter motor won even try to crank
    By vs1997II in forum Electrical Wiring / Questions
    Last Post: 30-06-2010, 09:31 PM
  3. VS AUTO problem> oils goes black after oild changes.it wont engage in mornings start
    By joemole in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2010, 08:23 AM
  4. Motor turns over but wont start...
    By Stellaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2009, 09:36 PM
  5. WB Statesman blue 308 motor wont start..
    By BOGANV8 in forum General
    Last Post: 03-08-2008, 04:52 PM
