Results 1 to 3 of 3
Thread: VH Gas to fuel switch?
    VH Commodore ( Paddock Bomb)
    Jun 2010
    Default VH Gas to fuel switch?
    My paddock bomb has a gas conversion kit in it, and it was running on gas when i bought it. It didnt stay running long enough to run out of gas and make me switch it to fuel so i'm not sure if it works. But i did try once, and the car just turned off so i assumed it did have a fuel system but it was just empty. Yesterday i was cleaning all the broken glass out of it and noticed the gas to fuel switch isnt even connected! And seeing as it's a paddock bomb, i can't drive it to town and fill up the gas tank. I've decided to just rip the gas tank out and keep it on fuel but would it just be easier to run some fuel line straight to the new motor when its in or will the gas tank cause problems because i've noticed both the filler caps on the outside of the car run straight to the it. Is this normal?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Jun 2010
    I guess this was a stupid question as i had a good look today and no, it's still there. And after ripping the gas tank apart i found the one of the tubes has shit in it, but doesn't actually connect to one of the filler caps so i guess its all good. Ripped out all the gas lines and whatnot. Removing the tank is turning into a real headache.
  1. Post on how to wire up headlight off switch to interior light door switch
    By Bookanun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 12:19 PM
  2. Oil Pressure Switch Disbaling Fuel Pump
    By Brin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2008, 01:49 PM
  3. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
  4. Factory Gas Question, Fuel Switch Problem
    By be_inspyred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2006, 11:17 AM
  5. Fuel trouble? pump won't switch off
    By MickDuprez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 07:03 AM
