well i posted anotehr thread saying the car wouldnt start but we got that fixed, now the macanic that was here found another problem he took it for a drive n white smoke was coming out from the gearbox n you can smell the transmission oil i think and it just burns and it keeps slipping? its been sitting for about 3 months and before it was good no problem with it... is it blown?
Thanks
um, sure it isnt just a leaky rear seal letting oil onto the flywheel/pressure plate?
The car is automatic So it has a flywheel and im not too sure its had an oil leak for somtime
Where exactly is the smoke coming from?have you checked the transmission oil? I'm thinking it's leaked transmission fluid onto the exhaust ,which is making it smoke and slip.
cracked modulator on gearbox, engine sucking trans fluid up through the vacuum line and burning it?
