Results 1 to 10 of 10
Thread: lowered vk
    vn
    Nov 2009
    noble park
    Default lowered vk
    my vk has red springs think there pedders maybe and guess it 2 inches lower than standed anyway ive noticed that when i jack it up the rear springs fall out.
    Can i get shorter rear shockies?
    VC
    Oct 2008
    Yes you can get shorter shockies. I have Koni sport adjustables, not cheap but good. I would think Pedders would have something as well.
    VS Calais & vh sl
    Dec 2006
    deception bay
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by 180sc View Post
    if ti hasnt already got one chuck in the adjustable panard bar aswell.
    Or, you can cabletie the springs in and put the panhard bar in a vice and bend it :P
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VK Berlina/VX S Pac
    Jan 2010
    Central Coast
    Just bought lowered Monroe shockies for my VK as I had the same problem, already have the adjustable pan hard on there. But all this leaves me with a new problem,
    "How low do I go?"
    VS Calais & vh sl
    Dec 2006
    deception bay
    dont go to low cause even with adjustable strut tops it will chew your front tyres out pretty quick. i had my old vc dumped right down to 80mm lowest point and front tyres only lasted 15000k before they had wire hangin out the inside edge.
    vn
    Nov 2009
    noble park
    adjustable panard rods whats 1 of them gunna cost? any chance of a picture of 1? has any 1 shorted a pan hard how would i work out the exact length if i was going to cut a bit off 1?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    150 for the rod including neolathane bushes
    cutting it and welding it will work too. lower the car to the height you want, rock it around so the springs settle down to where they would be day to day, then measure the space btween the rim and the wheelarch on both sides, and cut off the middle measurement, so if the pass side has 0mm and the drivers die has 50mm the you need to shorten the panhard by 25mm but not only do adjustables have adjustment, they also are bent around where you exhaust goes. and trust me... the exhaust hitting the panhard is the most annoying sound you will ever hear.
    also monroe gas lowering shocks are the cheapest i have found so far 80 bucks for a pair.
    edit* WTF is that guy doing in the pic you posted????
    sed8's Avatar
    sed8 is offline commodore nut
    vr ute @ vk calais
    Feb 2005
    brisbane
    buy an adjustable there easier and if you search ebay you'll be able to get one for under the 100 mark
    if it doesn't have a lion in the badge it not worth having
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Cool
    Would be annoying, but not as annoying as when the rubber mounts break off and when ever corner left every side of the uni taps the exhaust. :P
  1. Lowered With A Kit?
    By RhysVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2006, 12:08 PM
  2. lowered car
    By vpallme in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 12:45 PM
  3. Just lowered the VN
    By Evman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2006, 11:50 PM
  4. Lowered VS
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2005, 07:17 PM
  5. vr ute lowered
    By EZRA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2005, 10:25 PM
