Does VR VS type central locking fit VB VC VH?
If you mean be able to work in a vb/c/h ...not really as will have to adapt the wiring to suit it ....big job ...also lock motors i doubt will .I have a jaycar kit in mine which is probably a better option...not very expensive and easy to install once you work out where to drill the holes in the doors/pillars easy.VBs use a couple of circuit breakers mounted external to the fuses near the headlight switch standard feeding a couple of n/c,n/o type relays. VRs use a body control module to do the switching but vn/p use a separate remote mounted module fed from a fuse.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
Working is a big job I am sure but more wondering if the door latch with motor will bolt in to the door.
you can make anything fit anything, as long as you have enough beer and a welder. why bother though? when a central locking kit is 45 bucks and is the easiest thing on the face of the planet to install.
plus you can install the after market kit into the factory holes, and mounts make up the link arms and change a couple of pivots ont he rear doors and it will work as factory.
cheers
Scott
Thanx guys, was more wondering if the later ones will bolt straight in, I will persist to get them working if they fit.
