Results 1 to 4 of 4
Thread: est light
    Nov 2006
    Default est light
    hey the est light comes on when driving my vk what is it and how do i fix it thanks ben
    VY Ex-cop
    Mar 2006
    electronic spark timing, means theres a fault in it somewhere and your in limp home mode. normal fault from memory, throttle position switch, check to make sure the contacts are closing when at idle. if not, adjust.
    vn
    Nov 2009
    noble park
    Default he-1
    get a he1 distrubutor from either an injected vk or a vc -vh.
    throw the est as far as you can
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    It means there is an issue in the system (its the same as a check engine light), could be sensor or actual computer. There is a wire behind the rocker cover at the back in the main harness that you earth to put it in diagnostic mode, it will make the EST light flash and give you codes. Eg 1 flash slight pause, then 2 flashes = code 12, will try to find a list of codes, have it somewhere. Earth the wire with the engine running when the light comes on next.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  3. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  4. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
