Results 1 to 16 of 16
Thread: exhaust taps on fuel tank :S
    RippleEphex's Avatar
    RippleEphex is offline VS Wagooon
    95' VS Wagon
    May 2010
    tassie
    Post exhaust taps on fuel tank :S
    on the VH its had a new exhaust in the last 5 years at some point, i have checked the rubbers and theyre still fine, except that it sits a little bit close to the fuel tank and taps very loudly because of the rough starfire engine when cold once it warms up its fine because the motor runs smoother but rough when cold
    any ideas on how to stop it tapping?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    i used a stack of left over cork gaskets, the bits that you rip off from around your new ones, glued them together with RTV then glued them to the boot floor, but in your case the fuel tank, i never heard a noise from it again.
    95' VS Wagon
    May 2010
    tassie
    85 VK SL - 79 VB 253
    Jun 2009
    NSW
    I always ensure my victims are unconscious before placing them in the boot....
    Oh, wait....
    ari666's Avatar
    1966 impala
    Mar 2009
    efi 202 torana, vk project car!
    Mar 2010
    mount gambier sa!
    i used to use cardboard. like not weetbix box cardboard but like the thicker stuff. used it behind the numberplate to stop that horrid vibration when ya crank up the bass. id say cork gasket would be butter for under the car because it doesnt soak up water lol!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How about fixing the problem instead of hiding it?
    What you will need to do is loosen the clamp that holds the rear muffler to the front muffler just behind the diff, rotate the rear muffler slightly clockwise looking at it from the rear, this will pull the exhaust away from the tank a bit. You may have to bend the rear exhaust hanger over towards the tank a touch to pull the rear away from the tank as well.
    If that doesn't work, you will have to remove the rear muffler and pull the front section over to the passenger side of the car, then refit the rear muffler. Removing the muffler gives you more clearance and you can pull it over more. You can do it by just removing all the rubbers as well, but the rear muffler doesn't have much room between the tank and the spare wheel well.
    Visit my Facebook page
    ari666's Avatar
    1966 impala
    Mar 2009
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I know this site can be known as Just Pieces of Shit, but why facilitate the rumour?
    ari666's Avatar
    1966 impala
    Mar 2009
    95' VS Wagon
    May 2010
    tassie
    they should make a new section "bush quick fixes" , thanks Not_An_Abba_Fan helped a lot, good to know how to do things properly as well as the "bush way"
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by ari666 View Post
    lighten up
    I guess humour can be very hard to convey in text unless it is obvious huh?
    ari666's Avatar
    1966 impala
    Mar 2009
    i must admit to something:
    4 cylinder starfire
    soon to be a 202
    bonnet scoop +
    rear spoiler, both painted with aerosol cans
    kinda threw me off the whole "lets do it properley" trail, so for that i apologise *bows*
    95' VS Wagon
    May 2010
    tassie
    its the lets do it properly if it doesn't cost money thing :P doing what i can
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
    i am assuming you will be upgrading your exhaust when you go 202 right? that 4 pot would have to have a pee-shooter exhaust from stock
  16. #16
    95' VS Wagon
    May 2010
    tassie
    yeah i reckon, doesnt look that small but would have to look, will save up the money so i can do as much as i can at once, so i can go straight from starfire to 202 with proper vh brakes, diff and suspension (probably find a donor car)
    oneday will put something bigger in it (ls1 or something hopefully, thats on the wishlist)
  1. Fuel Tank,Fuel Pump Assembly and Swirl Pot.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2011, 10:12 PM
  2. [VIC] Fuel tank & reco fuel injectors
    By BT1-355 in forum Parts And Other Items For Sale
    Last Post: 25-11-2009, 03:36 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. Very bad fuel odors and presure in fuel tank
    By Helicopter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2008, 01:29 PM
  5. Monaro fuel tank into VX, fit twin exhaust
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:47 PM
