hey i have a 202 with 10.5;1 compression, i want too get it turbs, but im contemplating is it a good idea with heigh compression? it has other work done too so its a strong hardy engine, im just undicided?
stick to around 7psi will help it breath easy and give it a huge boost in power they go good with a turbo on
If your going to go turbo then just make sure you got plenty off fuel and tune it all in correctly and run the right type off fuel and you should be ok ive seen some interesting power figures from efi 202's just don't go to high with the boost i wouldn't push it past 7 but i have seen some push past 10psi.
