Results 1 to 5 of 5
Thread: VK V8 radiator pressure.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Default VK V8 radiator pressure.
    Does anyone know what kind of pressure a stock standard Vk V8 radiator will take? stock is 105kpa. Is it possible it can take 135kpa or will it blow or eventually blow?
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The radiator will probably handle it but the heater element probably wont. A lot of cars only have low pressure heater elements that eventually give way
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    hmm never thought of that, reason i ask as i wanted to use a Vk v8 radiator i have for when i do my V6 conversion, as V6 has system pressure of 135kpa and Vk 105, so any ideas of what running the V6 system at 105 would do to the Engine cooling performance? just lower boiling point wont it so it it wont get as hot before it can no longer cool?
    VB SL/E
    Dec 2008
    Running a lower rated pressure cap will probably cause hot running temps and the overflow system working overtime, if you are unsure of the heater core then wip it out and take it into a radiator shop and have them test it to at 135kpa.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Its easy said then done to just wip the heater core out lol, im leaning towards a trial and error approach...... if it works with a 105 cap ill leave it be, but if it runs hot ill have to change it, might see if i can get my hands on a second hand heater core to test. also being a V8 radiator should help things as it would be larger then a standard V6 item.
  1. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  2. radiator cap pressure
    By student in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2006, 08:18 PM
  3. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
  4. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
Tags for this Thread
