Results 1 to 10 of 10
Thread: Varajet losing its fuel from bowl
    RippleEphex's Avatar
    RippleEphex is offline VS Wagooon
    95' VS Wagon
    May 2010
    tassie
    Default Varajet losing its fuel from bowl
    i know ive put up a threads on the varajet 2 , but ive got another question.
    it seems to be losing its fuel out of the fuel bowl, any ideas why?
    its a reconditioned one ive just put on
    ive tightened everything
    looked for leaks but cant see any
    i try and start her up after a week and she wont go unless i put fuel in it and even still it has a hard time
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    most carbs will evaporate fuel. not really much you can do about it. even my commo needs to have a few seconds before start up to fill the fuel bowl and i drive it everyday.
    the problem is carbs need vents so they can work properley and all your fuel evaporates from there. that is assuming there are no leaks like you say. but yeah, a week in between starts should pretty much drain it. you just need to crank it a few times before you start pumping the gas pedal
    95' VS Wagon
    May 2010
    tassie
    thanks ari666 maybe the old one wasnt venting properly or something and thats why it kept the fuel (it was pretty dirty), just wasnt sure if there was something i didnt do with the new reco'd one. it had been left for a week so it makes sense
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Air666 you should put a little button under the dash to manually operate the fuel pump so it will prime up and start first kick. Did it to my 5ltr cause it was forever cranking because it rarely gets driven.
    95' VS Wagon
    May 2010
    tassie
    id put in a button but its not an electric pump , ive got a good look at it today, when i primed it it was leaking out of the arm that goes up and down on the side (i think its the plunger arm maybe?) and because its parked on an angle it leaks out that bit, so i think if i park on a flat it should fix the issue. the old carby must have had enough dirt/oil in it to seal that up
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    95' VS Wagon
    May 2010
    tassie
    i have parked on a different angle tonight to see if it makes any difference, it should be in correctly because it works great (but then i didnt rebuild it so i cant tell)
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    There would be a seperate seal to stop fuel coming out and thats whats leaking i would imagine, the plunger itself doesn't seal to he outside world.
    ari666's Avatar
    1966 impala
    Mar 2009
    your 100% right VKsl202. that plunger shouldnt leak at all. my guess is the diaphram inside it is dud.
    this is one from a quaddy, i assume its the same. the blue bit in the pic is the diaphram that fell off the pump (in my hand)
    got some more pics somewhere, i will try and dig them up.
    pic added
    Attached Thumbnails Attached Thumbnails Varajet losing its fuel from bowl-100_1355.jpg
    95' VS Wagon
    May 2010
    tassie
    thanks for the pics i might take apart the old carby (practice on the old one first) and see what i need to watch out for when im taking it apart, another thing i think my new carby is off a VK not a VH (seems to be a newer model varajet 2)
  1. Varajet II
    By bang_chong in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-06-2010, 06:35 PM
  2. Losing Fuel At A Rapid Rate
    By JohnyRock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 03:14 PM
  3. Varajet adjustments
    By 85berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-09-2006, 07:32 PM
  4. Varajet II to Weber34adm
    By cecil strike in forum Straight 6 Development And Modification
    Last Post: 26-06-2006, 07:05 PM
  5. tweaking varajet ?
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-01-2006, 10:08 PM
