Results 1 to 7 of 7
Thread: T5 into VK gearbox mount question
    VT Berlina S2 5.7
    Mar 2009
    Default T5 into VK gearbox mount question
    I've bought a Holden T5 V8 conversion for my VK recently and have started the conversion.
    I was told the I needed a VN crossmember and gearbox mount to fit to the gearbox but it doesn't have the VN crossmember but a VK item instead.(this was all taken off a running car)
    Would the VK member suit the T5 and what gearbox mount do I use,the VK or VN one?
    I've tried fitting the VN mount to the VK crossmember but it just does not sit right.
    Sorry for sounding so confusing.
    Any help would be appreciated.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    You dont use either mount, check my site for details I have info on mounts etc.
    cheers
    Scott
    VT Berlina S2 5.7
    Mar 2009
    I've got that exact crossmember, I think it was from Dellows.
    Anyway, So I can just use a TH400 gearbox mount?
    vk
    Jul 2010
    adelaide
    hi there i just rang rare spares and no luck with the vk t5 crossmember its been taken of there list
    vy2 clubsport
    Feb 2008
    adelaide
    just buy a t5 bearbox mount and elong[re drill the holes] its cheaper/faster/better then buying something you dont realy need lol.and you wont have to drill it out much more either just a little bit
    LX SL/R torana, HZ SANDMAN, VH SL/E top 30
    Apr 2009
    BALLARAT
    HI guys. Just following on from this, i looked at VKberlinas site and he showed the t400 mount. So just to get this clear...
    Does a T400 mount bolt to a T5 gearbox? And does the T400 mount then fit onto a T400 or trimatic crossmember with slight slotting out of the holes? Do i have that right?
    And does this all then sit at the right height?
    Any clarification would be great. Cheers.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Yes the T400 mount bolts up thats why its pictured on my site bolted between the crossmember & gearbox. I couldnt get mine to line up on the thaumatic crossmember thats why I used the other unit.
    My setup sits perfect.
    scott
  1. Engine Mount Question
    By mick_VTSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-12-2008, 08:52 PM
  2. MC6 gearbox, where does the mount go?
    By Com_VC in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-12-2007, 11:41 AM
  3. Qwik strut mount question.
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-05-2007, 12:05 AM
  4. Corvette servos and new gearbox mount own!:P
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2007, 08:38 PM
  5. High mount log manifolds VS front mount extractors
    By PaRaDoX in forum V6 Development And Modification
    Last Post: 04-04-2007, 06:15 PM
