Hello,
I have recently purchased a Holden VK with the Holden 304 5L EFI engine.
OK: The engine started leaking oil, I noticed when I parked and there was a big puddle of oil underneath, Now whenever I drive there is oil just dripping and leaking. Now I am not driving the car until i fix it..
I have Inspected the Valve covers and gaskets and they are fine, It is not leaking for there.
The leak seems to be coming from the Rear of the Intake manifold / distributor area.. Today I cleaned all around the rear of the intake, started the car up, and after 5 minutes I see oil leaking.. So it has to be coming from somewhere there..
What should I do in this situation? Should I just remove the whole Intake manifold? Are there any tricks?
Here are some Photos:
This is the 304 V8.. Im pretty happy with it.
This is where it is Leaking from. You can see the Oil.
That is the best photo i could take, So i am assuming that it has to be leaking from there somewhere?
This is the top view, You can see a bit of oil where the intake manifold meets the block..
I appreciate any help on how to fix this problem..
Thanks a lot to Everyone,
Mati
Mati
