Results 1 to 17 of 17
Thread: Whistling 202
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Default Whistling 202
    Now that its winter again my 202 has started to whistle randomly, it only does it in the cold weather and only after the engine warms up a tad, will come and go randomly but then goes away after for good about 15-25 minutes driving depending on the temperature. Is really inconsistent, it will whistle after you accelerate giving low vacuum on the manifold and then back off or be on the overrun pulling high vacuum but wont whislte all the time /every time, does it best when you go over a steep hill, it will whistle until about halfway down the other side then slowly get quietet and then stop even though the amount of manifold vacuum is the same (i have an economy gauge still).
    Removed the line for the dash controls, air pump diverter, replaced the PCV valve, disconnected the economy gauge, gone over my vacuum lines about 100 times and found nothing, no cracks splits ect.
    Really hard to track, if you get it to whistle then pull up, by the time you get the bonnet open its gone.
    Idle is consistent and smooth, fuel economy is fine, manifold bolts are tight.
    Any ideas on what part would cause such an awesomely annoying noise?
    Vac diagrams are on Scott's site
    VK Berlina Project
    commodore vk auto 3.3 everyday car
    Oct 2009
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Did have it apart a year ago to put new bearings in it but its not rev related and cant get it whistle by reving at idle while your under the bonnet so i doubt thats it.
    GenReaper is offline Donating Member
    VY SS Series II Wagon
    Aug 2009
    Radelaide
    Pretty sure they run an EGR diaphram and that could be split.
    Pull off the line to the EGR and plug it and if the noise goes away there is your problem.
    http://forums.justcommodores.com.au/signaturepics/sigpic58904_1.gif
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Yeah ill do it tomorrow morning, if it not that its got to be diaphragm somewhere........ they have quite a few around the place.
    VY Ex-cop
    Mar 2006
    ive seen a few whistling commodores of this model, pour a bucket of water over the manifold when its whistling if ya can and see if it dissapears, maybe an inlet manifold air leak as well.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Quote Originally Posted by ari666 View Post
    TVS leaking. i reckon you may find a hairline crack in it.
    And here I was thinking u were gonna say something
    Like "that's cos it's a 202, get a 308 and it'll stop"
    Hahaha
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    Aug 2009
    Radelaide
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Well EGR wasn't it, little throttle nudger thing wasn't it, all the air pre-heat system wasn't it. Couldn't find any leaks in the manifold gasket but not to rule it out all together as it could be leaking from the bottom.
    So TVS sounds like a good one, most likely the one that operates the vacuum to the little flap in the exhaust actuator as i discovered the EGR valve doesn't get any vacuum at all at idle an on overrun and thats what the other TVS is for. Makes sense, wont whistle when cold cause thats open but when it closes the vacuum is drawn through crack then when engine get fully warm plastic expands then closes up the gap. Will give it a go anyways......
    Project_HR's Avatar
    Project_HR is offline Budget Buster
    VL V6 Turbo'd Sedan, Turbo'd V6 Altered
    Apr 2008
    Noo Zilland
    maybe it is a happy little 202 ..... I sometimes whistle when I am happy .....
    Turbo's give cars their best ever blowjobs !!!
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Aug 2009
    Radelaide
    One good way to find vaccuum leaks tho not recomended...
    Get a bucket of water or fire extinguisher for safety.
    Put some petrol in a tin and use a paint brush and dab the paint brush in the petrol and then dab it around the intake manifold and any accesories that run off the intake manifold.
    If it picks up RPM then you know you have a leak in that particular area.
    I cannot hense the safety in doing so, but it does work, an old mechanics trick.
    If you do this just be carefull and using little on the brush at a time to reduce the possability of a fire.
    Best do it when cold engine as to not spill any on a hot exhaust manifold and obviously keep it away from ignition leads.
    If it doesnt pick up RPM on the intake manifold its possibly the exhaust manifold ports leaking or possibly even a cracked exhaust manifold.
    Just something you could try but be carefull when doing so.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Ok, today disconnected the TVS on the way to work and it didnt fix the problem, so after work drove it in the shop and had another look over everything, i found 1 loose manifold bolt, the one right at the back.... i missed it before cause it was dark and assumed that it was like the red motors i had always played with and just had a stud with no nut. Wrong! Tightened him up and drove home and so far havent heard a peep out of it, so fingers crossed!
    If it still whistles i will go for your approach GenReaper. Thanks all for your advice.
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
  16. #16
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by VK SL 202 View Post
    Quote Originally Posted by TheIceman View Post
    yep, i was right though, ive fixed umpteen number of whistles by tightening manifolds on those comomdores and most diganosed by the bucket of water. never have i used petrol, i have heard of it, but water does similar trick, u will notice engine change as soon as water gets sucked into a small hole.
  17. #17
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Thumbs up
    Never got a chance to use the water trick while it was whistling as it never whistled at idle, it would only for a few seconds after you pull up and i would hop out and try to find it, by then it would be gone , but shes all good now!
  1. whistling noise?
    By msina1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2009, 08:58 PM
  2. whistling vk
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2008, 07:50 PM
  3. whistling intake
    By guyver6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2006, 10:14 PM
  4. Engine Whistling?
    By JTW008 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2006, 01:32 AM
  5. My Vr Is Whistling
    By bizzo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2004, 11:13 PM
Tags for this Thread
