Results 1 to 12 of 12
Thread: has anyone made a custom vk dash?
    VS ute
    Jan 2010
    townsville
    Default has anyone made a custom vk dash?
    hey all.
    as the title states, has anyone made a custom dash for there vk? even vl's or earlier models?? Im looking at doing this next week. would like to see some pics of end results or any ideas/tips..
    i was thinking of using the current strip of warning lights/indicators that is under the instrument cluster. then cut out some wood to fit the rest of the gap in the dash and cover in leather or vynal.
    any recomendations for guages? if i go vdo gauges can i use current senders? (apart from speedo)
    cheers
    pat
    VK executive
    Dec 2009
    Brisbane, Caboolture
    i think some people have mate, and i would like to custom mine aswell as i don't like the current one, not sure how to go about it
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    i have kinda made one. i started and never got around to finishing it. i dont think i have a pic though, will hunt around. but basically its where the little buttons go. i cut all the buttons off, save for the heater control, and fitted a flat bit of plastic in there, cut out a 60mm hole and in goes my cheap arse ebay vac guage, which has now stopped working.
    it looks really fail at the moment, but when the impala isnt taking all my time i will set to and bog/shape it and spray it properley.
    VS ute
    Jan 2010
    townsville
    sounds good. im looking at taking the dash out completely and having an aftermarket speedo, tacho, volts, water temp, oil pressure and fuel gauge. using the original warning lights.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I am considering putting in the VP tacho cluster into my vk when i do a V6 conversion but still using the original warning light strip and vk cluster face with the middle bit between the gauges cut out and then the vp gauges stuck in behind for a semi stock look or something along the lines of that.
    VS ute
    Jan 2010
    townsville
    ok i have made a backing plate. it will be covered in black vynal and looking at getting white gauges. only trouble is finding a km'h speedo and tach that are 70mm or less and fuel, volts, oil press, coolant temp and clock that are 4cm or 1 1/2" i have found gauges these size but none that all match up as a kit. any help will be appreciated. il try take some pics
    VS ute
    Jan 2010
    townsville
    VS ute
    Jan 2010
    townsville
    hdt_027's Avatar
    hdt_027 is offline Brock 05
    VK SL
    Jan 2009
    Bathurst, NSw
    Hey Mate, heres some pics of a custom autometer dash i made myself.
    Attached Thumbnails Attached Thumbnails has anyone made a custom vk dash?-img_7315.jpg   has anyone made a custom vk dash?-photo014.jpg
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    heres a couple for you, I have a 1/2 finished custom insert for my VK, I closed in the holes in an original cluster and when i can justify spending the money plan on a VDO classic set of guages. It took about 2 full days plastic welding the panel up ready to cut holes in it for guages.
    what I dont like about the custom sets, they always look tacky around the demister & electric antenna dash buttons.
    cheers
    Scott
    Attached Thumbnails Attached Thumbnails has anyone made a custom vk dash?-interior_pop.jpg   has anyone made a custom vk dash?-07_1.jpg
    D22 St-r Navara
    Dec 2010
    perth
    there is a website for a company in america. that will mod your dials into a fully functioning digital display for around a grand
    ari666's Avatar
    1966 impala
    Mar 2009
    hey scott, where did you move your heater switch to? i did a similar thing, but cut the button pad in half so it retained the heater button, but am a bit over it.
  1. Custom made king springs?
    By ccw90 in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-08-2009, 04:46 PM
  2. custom made vn parcel shelf
    By potshots007 in forum Parts And Other Items For Sale
    Last Post: 28-09-2008, 07:52 PM
  3. Just made some custom Dials :)
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 10:19 PM
  4. Custom Made Gauges!
    By rot10n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-12-2005, 06:31 PM
