Results 1 to 4 of 4
Thread: sle project q's
    vh sle !!!!! is offline 262MANTER
    VH SLE, VB commodore
    Sep 2008
    Default sle project q's
    hi all
    firstly can anyone tell me which line out of the power steering rack is the return and which is supply???
    secondly has anyone done a booster and master cyl upgrade on there vb-vk if so info would be appreciated or is it poss to do the same as vl How to adapt the VT Master Cylinder to early model Commodores - calaisturbo.com.au
    cheers trent
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    when you start the engine and turn the steering wheel, the return line is the one without fluid pissing out of it...
    Sep 2008
    VB SL/E
    Dec 2008
    The return line is low pressure, hence it will be similar to heater hose in construction (but don't use heater hose lol) the supply hose is high pressure and constructed like hydraulic lines or A/C hoses with pressed sealed fittings on the ends to contain the high pressure.
    Hope that helps.
  1. My VK Project
    By DanielGreen in forum VB - VC - VH - VK
    Last Post: 31-01-2011, 10:33 AM
  2. My Project Vk
    By Dirbatua in forum VB - VC - VH - VK
    Last Post: 27-04-2010, 09:24 PM
  3. my VC Project
    By phayZd in forum VB - VC - VH - VK
    Last Post: 19-10-2009, 02:57 AM
  4. Project: WMC
    By Niggadore in forum Car Audio
    Last Post: 18-07-2008, 01:26 AM
  5. VK 308&383 Project
    By SthEastCustoms in forum Projects
    Last Post: 28-12-2006, 02:22 PM
