Results 1 to 12 of 12
Thread: my VH commodore
    VH SL 202
    Feb 2010
    Default my VH commodore
    hey everyone i have a vh commodore and im swaping the motor from the fked blue 202 to another one hehe i wanna drive it on my P's so yer anyways i wanted to ask dose anyone know if i wouls be able to to get rid of the clutch fan and put in twin thermo fans or maby evan one hehe and also dose any one know how to get the chrome bit back in the head lighs mine are dull n worn like hehe im also looking for the chrome bits that go around the bonnet and top of the head lights
    VS Calais & vh sl
    Dec 2006
    deception bay
    You should be able to run a single 16" thermo no worries on the six so you can ditch the power sucker. Headlights get new ones the aren't dear about $70 of ebay for a pair same with the chrome trim keep your eye out for them on ebay they pop up every now and then.
    VH SL 202
    Feb 2010
    Quote Originally Posted by 180sc View Post
    thanks for that umm i just need to know the wirering part for the thermo do you know how to or dose anyone els know how to
    CV8 Monaro
    Jan 2010
    wiring up a thermo fan is easy, just get a temp sensor and i can help you out with it if you want
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    meh, temp sensor. hard wire that sucker.
    get a relay:
    run
    pin 85 to ground
    pin 87 to the + terminal on your coil
    pin 86 to the battery
    pin 30 to the fan
    the numbers are on the base of the relay. i would suggest getting a relay holder (narva part number 68084) because its neat and easy to change relays later if it goes pop, but normal blade crimp terminals fit.
    CV8 Monaro
    Jan 2010
    you could hard wire it if you want it on costantly how ever if you want it to come on at a certain temp by itself you need to do it via a sensor
    also if you follow your instructions you wont get it working
    Pin 30 goes to the positive side of the battery or an acc wire so it turns on and off with the key, not to the fan
    Pin 85 goes to the ground
    Pin 86 would usualy go to the switch to turn it on but if you want it hard wired loop this to pin 30 so it gets power to it
    Pin 87 goes to the fan
    the other wire on te fan goes to ground, if the fan spins the wrong way just switch the 2 wires on the fan around
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by hypedz View Post
    LMAO! i love how people on JC contradict you, just for the sake of contradiction.
    VK V6
    Mar 2010
    NZ
    Not just for the sake of contradiction, your wiring above was wrong
    edit: not that the second version above is much better, if you wire both 30 and 86 directly to the battery the fan will never turn off
    VH SS
    May 2009
    Toowoomba, Qld
    stick with the clutch fan mate, they shift more air than a thermo, disengage when not required, are more reliable, and actually draw LESS power from your engine (contrary to popular belief). If you do plan on running a thermo, remember that the power doesn't come for free. Your alternator has to generate it and your engine has to drive the alternator. So find out the current draw of the thermo fan, and then look at the output of your alternator. A good quality 16 inch fan (eg davies craig) draws close to 20 amps, blue 6cyl Commos only had a 45 or 55amp alternator, so combined with your ignition system and other accessories you wiil more than likely end up with a charging issue. For example, if you end up in traffic on a rainy day, with headlights, wipers and thermo fan blowing, your alternator won't be able to keep up - battery voltage is going to drop severely - been there, done that.... wipers almost came to a standstill and headlights went a dull yellow.
    So you are probably going to need look at adding the cost of a higher output alternator (ideally 75amp), large gauge wiring capable of handling 20 amps or more, good quality electrical connectors or everything melts and you end up with an overheating engine.
    CV8 Monaro
    Jan 2010
    Quote Originally Posted by VK_3800 View Post
    that is why i wrote or ACC WIRE SO IT TURNS ON AND OFF WITH THE KEY, read all the post first
    ari666's Avatar
    1966 impala
    Mar 2009
    oh pooh. googled pic has the wrong numbers on it lol. sorry OP!!! i shouid've just looked at a relay.
    need to swap numbers 86-87 over
    while we are on the topic.. does anyone know if the standard temp sensor will provide enough resistance while cold to not switch the relay, i.e. bridge into the temp sender wire with pin 85, and use it as the relay earth?
    CV8 Monaro
    Jan 2010
    yes you can, i had this same set up on my old celica
  1. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  2. Replies: 6
    Last Post: 17-05-2009, 10:57 PM
  3. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  4. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
