Results 1 to 4 of 4
Thread: VK engine
    elmaso's Avatar
    elmaso is offline PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    Default VK engine
    hi all (i'm new here so if this isn't the place to post, sorry) anyhoo do you need an engine re-build to bolt on a turbo to a vk 6 or will it work at a fair efficiency without a re-build?
    vn
    Nov 2009
    noble park
    a mate of mine is into turboing 4wds hell just bolt them to any engines, ( and make all the piping ect) but no engine work, if the motors nadded and theres no point hell tell ya that (most of his customers are only a few years old).
    but the engines he rebuilds for turbo make more power.
    horse-power is directly proportional to cash flow
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Yes you will need to rebuild it otherwise it will ping its tits off. Lower compression ratio plus other things are needed to be suitable.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    if you need to lower the compression ratio you can install a thickerhead gasket the turbo guys can put you onto a decompression plate or if your serious an o-ringed copper gasket.
    scott
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  3. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  4. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
