Results 1 to 11 of 11
Thread: Starfire engine mounts worn out?
    RippleEphex's Avatar
    RippleEphex is offline VS Wagooon
    95' VS Wagon
    May 2010
    tassie
    Default Starfire engine mounts worn out?
    so today i was driving along the highway, straight road, all of a sudden the car starts vibrating, but whenever i go over a bump if stops for a moment. because the engines not at heavy on the mounts for a quick moment
    it smooths out when im at speed and the engine is revving, but its still there just not as much
    im 90% sure the engine is fine because it does run fine if the motor isnt shaking about (like starfires do)
    if im accelerating the the motor is running smooth then it doesnt do it at all
    are the engine mounts worn out?
    they look pretty old
    95' VS Wagon
    May 2010
    tassie
    so i took it into the auto shop, and it needs new engine mounts, but no ones makes starfire mounts anymore.
    so i desparately need some engine mounts for a VH starfire motor?
    does anyone have some i can buy and have sent to me?
    6cyl ones are different to 4cyl ones
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    im pretty sure if you ask the wrecker nicely he will include the engine mounts with the 202 you are going to buy off him.
    95' VS Wagon
    May 2010
    tassie
    yeah just exploring that option now, just have to find a place that can do it for me, id do it myself but i just dont have the tools and know how
    vr v6
    Aug 2009
    Whats different to the 6cyl ones ,i thought they where the same. The engine mounts on my torana where the same when i converted form starfire to 202.The only different's was the bracket from engine mount to block.
    95' VS Wagon
    May 2010
    tassie
    thats what i thought but i bought some 6cyl ones from repco, and the guys at the auto shop had a look and said nope they are different from 202 ones, i had a look myself before hand and they are very different
    VC
    Oct 2008
    Might be worth a check with Toyota as the Starfire was used in Coronas of the same vintage, they may have the same mounts and may still be able to supply.
    95' VS Wagon
    May 2010
    tassie
    yeah gave that a try to mate, they coronas has 2 bolts where the commo has 1 bolt on the bottom
    VC
    Oct 2008
    Check with Barsby Spares in Maryborough Qld they are a huge Holden wrecker with new and used parts. They have a website.
    95' VS Wagon
    May 2010
    tassie
    is there any way of refurbishing the old ones?
    heres pic of 4cyl, vc 4cly starfire questions
    sorry to steal photos from other thread
    VK V6
    Mar 2010
    NZ
    The Torana Starfires used the same mounts as the sixes, but somewhere along the line they changed them with the VH and VK at least having a completely different setup (both cross member and mounts).
    You must be able to find some good second hand mounts somewhere, a lot of people have removed them! It may be possible to have new rubber bonded onto the plates but I'm sure it would be excessively expensive.
  1. VT Engine mounts etc
    By discostuee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2010, 11:53 PM
  2. VR V8 engine mounts
    By ducatis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2010, 12:16 PM
  3. Engine mounts
    By VS-S-PACK-UTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2009, 10:50 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine mounts
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2005, 11:23 AM
