hey i was thinking of adding a air/fuel guage to my vh but i dont know if id be able to get it working i no that usally they run to the ecu and get the signal there but not sure on a carbi mortor i was also gonna put in a vac guage geting rid of the standard one and running an after market one and also puting in another guage but i dont know what els i dont want to many guages i want three on the dash just the 52mm ones notherin big and im not putting an a 5" tacho its just retarded well i think it is anyways let me know what ya think would be good to hear from ya
Yes you certainly can. I run an Innovate motorsport AFR gauge on my petrol Hilux so i could tune my weber properly. I bought the kit on ebay. It has the oxygen sensor, wiring,gauge and installation instructions. It cost around 320 dollars a couple of years ago.
run an oil pressure one i always do as the dash temp oneis plenty enough for its job and keeping an eye on oil pressure is a good ideas imo
yer thanks guys apreciate it hehe
im gonna getan air/fuel guage and oil and vac
go get yourself a second hand o2 sensor. you will need to weld a bung into your exhaust. it usually goes just before the cat, but your doesnt have a cat, so install it roughly near the trans x-member.
then go to jaycar and get this: Fuel/Air Mixture Display Kit - Jaycar Electronics
you will need to run a signal wire from the o2 to that unit, the o2 will need +12v and possibly earth, depending on what o2 you get. the o2 uses heat to send a pulse voltage to the display so this unit WILL NOT BE USEFUL FOR TUNING YOUR CAR! all its good for is displaying approximate afr's. you will need to hook the car up to a proper analyser first to zero out the display. otherwise it may say your running rich, but really itll be lean, or vice versa. and if your hooking it up to a alanayser... why not just ge it tuned then and there?
an EXPENSIVE vacuum guage is reaaaallly useful, if you have a holly.... if you have a variajet, its a waste of time. i bought a cheap ebay one, worked great, till it didnt work anymore. so dont waste your money on cheap, expensive s better.
also big tachos make you look like your blind/retarded. i agree that a tacho is very necessary, but big ones just make pppppffftt.
