Results 1 to 8 of 8
Thread: VK, cranking but no go????
    VT Supercharged
    Apr 2009
    Default VK, cranking but no go????
    HI,
    been off for a while, but with my VK project I changed plugs (had NGK but shop was out so got equivalent BOSCH) put them in started and in 5 seconds car crapped itself and now wont start.
    Mech mate stated they often had people with issues with BOSCH plugs and thought coil was blown.
    So I changed back to NGK, new coil, has a new dizzy cap, leeds etc, but still wont start.
    It is getting fuel (recond holley squirting well), and is getting some spark to plugs, so any ideas???
    jas
    VH SL 202
    Feb 2010
    it could be somthing to do with the timing of the spark it also could be the fuel air ratio have you tryed putting some throttle on to keep running
    VT Supercharged
    Apr 2009
    done and done, with no difference.
    The manual says to try the ignition switch??
    I checked the coild and getting 9-10 volts, but just wont kick over
    VB SL/E
    Dec 2008
    I think VK needs at least 11V to work properly, just like a blue motor.
    Sounds like weak spark.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    nothing wrong with bosch plugs at all, german stuff is the business. i find it highly unlikely that spark plugs are attributed anything towards your problems. you say the plugs are getting spark? is it nice and white/blue or dull orangey? realistically the coil should be getting a strong 12V to work, but also shouldnt stop it running.
    is it HEI dizzy? what part number coil are you using? have you checked the timing? where is you base timing with the vac advance line disconnected?
    does it WANT to fine, but just skips or is there no pop at all?
    VT Supercharged
    Apr 2009
    no pop at all.
    it cranks and cranks and nothing.
    I will have to check all timing again as been mucking around under bonet so may have moved it or something.
    been checking all wiring and voltage etc, so will double check as had some dodgey near igniton due to removal of old immobilser, (but was working after removal for weeks).
    was getting crappy spark and replaced coil yesterday.
    has NEW leeds, dizzy cap.
    aaarrrrgggghhhh
    PS its for sale now if someone is keen I think ad is still running but price is now much lower, or make offer...
    thanks
    ari666's Avatar
    1966 impala
    Mar 2009
    lol,
    1. what state
    2. how much rust is in the back window, boot and parcel shelf
    3. how much do you want?
    VT Supercharged
    Apr 2009
    its all in the ad in the 4 sale section under my user.
  1. Vt cuts out when cranking
    By johns496 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2010, 11:26 PM
  2. Slow cranking VT
    By SLAF in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 08:41 AM
  3. cranking problems
    By jimbojones889 in forum General
    Last Post: 09-07-2009, 10:46 AM
  4. Cranking but Not Firing
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 04:25 PM
  5. VR Slow cranking
    By CrazyDayz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:02 PM
