Results 1 to 3 of 3
Thread: Calibrating VK Speedo after Diff gear change
    VT Berlina S2 5.7
    Mar 2009
    Default Calibrating VK Speedo after Diff gear change
    So, i'm putting in some 3.7 gears into the VK which has a VL V8 diff and standard ratio.
    Gearbox is a Holden 8 T5, vehicle is sitting on 225 15x7 wheels.
    What's needed to re calibrate the speedo?
    If anyone has any info please let me know.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    A speedo gear for the gearbox, check my site for the gear chart, might have a bit of guess work as well as some calculations to work out the right one. Although my site is for Aussie boxes the normal drive and driven gear still applies, find out how many teeth your drive gear is and work out the driven gear. Else ask in the VR-VS section they might have charts as the T5 is more relevant to them.
    plus you may need to either source one from holden or drof depending on the one you need
    cheers
    Scott
    VT Berlina S2 5.7
    Mar 2009
    Thanks again mate.
  1. Diff gears/speedo change, it can be done by Holden
    By Troy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2009, 07:48 PM
  2. Calibrating Speedo
    By Sam_Vt5spd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2009, 08:00 AM
  3. calibrating speedo
    By Adamvr93 in forum V6 Development And Modification
    Last Post: 11-03-2009, 10:04 PM
  4. Change Diff Ratio - Speedo???
    By REXMAN in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-05-2006, 10:42 PM
  5. Speedo Correction after diff Gear change
    By gtrboyy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 12:54 PM
