Hey everyone!
Im new here and not sure if im posting this in the right area lol
My dad bought me a VK commodore back in April, there a quiet a few things wrong with it but as my dad is no longer talking to me i have no one to help
I know a lil about cars (i have fixed most of the cars prob so far) just terrible with diagnoising the problems so here goes:
New motor is in idles fine but after stoppin or slowing down when going to take off i have to baby it like it takes a good minute to get it up to 60kms or i have to flatten my foot and pray it doesnt die, 7/10 it stalls and im left to roll through intersections and with only one brake light n no hazards it can freak me out a bit!
Also there is a small rapid ping/tinging sound coming from under the hood i dnt know if this is related or not!
I dont have a lot of money so its a slow project for me but im really trying as i love this car soo much and couldnt bear to part with it but i am supposed to be leaving for a 1300km trip in 2 days and as is its in no way ready for the trip
Any advice or help would be much appricated, i dnt know how this site works but if people want im willing to provide a contact number
Is it a manual?
If it isnt manual and you stalling it, it is probably flooding when you plant it, if it is a carby, it isnt meant to be planted, or itll flood...
Could be your carburetor float (assuming it is a carby) and possibly timing way out.
Some more info on your car will help. 6 or 8, carby / injected etc
you have a carby?
what derek said. this car needs a good tune. from the sounds of it it hasnt had one for a while. also OP can you tell us what sort of level of "car talk" you can understand? i.e. if i explain how to set your base timing without a test light, would you know what i mean?
If it is a carb variety, sounds like a major vacuum leak to me.
Get somebody to check the inlet manifold for leaks. Might just need a tighten.
Look for hoses leading to nowhere on/near the carb.
Not only will vac leaks cause the mixture to be lean, but will reek havoc with the computer controlled spark.
TVS's (thermal vacuum switches - 2 on the carb side of the head) could be borked.
As derek mentioned, the floats are notorious for sticking/absorbing petrol on these girls.
Also, could be in "Limp Home Mode" if your EST is on the fritz. There will be a light on the dash lit up with EST showing. No chance of doing 1300k's if this is the case.
Really need to know if it is carb or injected tho.
it is runnin a 6 and it has a carby, red motor(202) if that helps.
Red motor? Has it been changed? What does the carb look like?
If its the original engine (not red motor), those Varajet carbs have a habit of flogging out the throttle shaft bushes. This results in the throttle butterfly actually moving sideways a bit as you crack it open, this dumps too much air in and gives similar symptoms to a vacuum leak. Pumping the throttle so that the accelerator pump squirts in some fuel to match this sudden rush of air helps a little.
my vk was doing the same thing. some fella told me to put some flash lube in with the fuel and it will stop. and it did
what sort of carby is on it ? If it's the factory carb, it should have a rectangle shaped top, with Varajet written on the side of the carb
If it's stalling, hesitating, bogging down and from what sounds to me from your description as 'pinging', then sounds to me as if the engine is leaning out.
You are probably going to need to do some work with the carb. Was it rebuilt along with the engine ? It's possible that the float level has been set too low.
Also as already suggested, check for vacuum hoses not connected and/or cracked vacuum trees. Usually vacuum leaks will result in poor idle, however some vacuum ports are only open under certain engine conditions, so it's still possible that a vacuum leak could be causing the problems
