Results 1 to 5 of 5
Thread: Fuel Tank leak
    VH
    Jul 2010
    Default Fuel Tank leak
    Filled the old girl up yesterday, parked the car on a slope came back at the end of the day to see a couple of holes in the bitumen under the car. Seems like the tank is leaking around where the filler neck joins the tank, the tanks is newish no cracks and all the lines have recently been replaced and are not leaking.
    Is this something that can be repaired or does it just have to be replaced. being the opposite side to the exhaust it should be okay to drive around? how much petrol do you think will be lost through vapor?
    VH SL/E 5.0
    Nov 2009
    Had the same problem with my last 2 VH's. Turned out to be the rubber return line that goes from the filler neck (I think)back to the tank. Always leaked when I filled the tank right up to the top. You need to drop the tank down to get to it. I got a mechanic to do my current VH when I was having some engine improvements done so not 100% sure what is involved.
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    VH
    Jul 2010
    Thanks Derek, at lest i am not alone on this one.
    I thought most silicon glues would be melted by the petrol and looking for a permanent fix really.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    once sikaflex goes hard its hard for life. we used to use them to fit restrictors inside filler necks (so you couldnt use the super pump on an unleaded car) and never had one come back.
    having said that, im sure there is a better fix. dunno if the tanks are the same but there is one massively annoying hose on the VK return which runs through a little bit of steel between the car and the tank, so you have to kinda half drop the tank, reach in, take off the hose calmp and remove the hose.
    i watched the wreckers just slice one in half to get the tank out. god those guys are dodgie.
  1. Fuel Tank,Fuel Pump Assembly and Swirl Pot.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2011, 10:12 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. Fuel tank leak
    By bigal in forum General
    Last Post: 03-03-2009, 07:51 PM
  4. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  5. fuel tank leak
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-11-2006, 11:34 AM
