hey everyone
im trying to pull my dash cluster out so im trying to pull the top dash peice off (in the car) i cant get the middle vents out iv taken out 2 screws there and iv taken out the bottem screws for the bottem part of the top peice i could see the screws up the back on the left but i dont know how to get to them i could use a long screw driver but i cant get the the one on the right side do i have to take the dash out of the car to get to it iv taken out the surround bit befor the dash cluster and iv taken out the dash cluster screws so i can move the cluster abit but i cant take it out so dose anyone know how to do this (take cluster out of the dash)
sorry I'm totally lost trying to read that, you need to use punctuation marks, sentences etc
Are you trying to remove the instrument cluster or the dash cover that surrounds the instruments ?
ok well you need to get the cluster out first.
If you've undone both screws on the sides of the cluster, then you need to get your hand up under/behind the dash and disconnect the speedo cable. That's probably what is holding it in. It's a mongrel of a thing to get to, so if you can't get to the cable this way, then it may be easier disconnecting the cable from the gearbox end, and then pulling the instrument cluster forward, then disconnecting the cable
