Results 1 to 16 of 16
Thread: vk 5 speed is sick pos dieing\
    vr aclaime ....vk exec manual
    Jul 2010
    adlaide
    Default vk 5 speed is sick pos dieing\
    hey my vk has lost power pings badly smoking coming out of the rocker cover cant even get 80 kph out of her even if i wind her out it over heated very badly after the thermostat failed to open nearly ceased
    go to start her she barly turns over try again say 2 more times she will then wind over fine and fire
    checked timing its all set properly all marks lined up at tdc any ideas was running perfect before no smoke coming out of the exust pugs r black but firing well im lost for ideas wife lives the car so gota fix it is it a rebuild maybe head gasket rings
    VH SL/E 5.0
    Nov 2009
    Sounds like you've dropped a valve.
    Check for oil in your radiator for to see if your head gasket is gone.
    Rebuild time....
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Smoke coming out the rocker cover is normal to a certain extent, what colour smoke? there will normally be a minor amount of white smoke come out, this smoke is caused by blow by - basically compression/combustion gases escaping into the crankcase past the rings, when rings are excessively worn or maybe in your case damaged you will get lots of blow by/smoke.
    But anyway i would say time for a rebuild, or drop in another engine. You could consider a V6 conversion or something like that as it may even be cheaper then rebuilding your current engine depending on the going rate fro Black motor parts ATM.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Jul 2010
    adlaide
    yes there is oil pressure but the needle moves around a bit with the revs no oil in the water no water in the oil no water loss the amount of smoke coming outa the rocker cover is noticable its white and blueish is running on all six cylnders even idls well as for the starting prob acts like the battery is flat but after 2 or more atmpts it fires like normal was told the windings in the electtronic dizzy could be at foult could this be it
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Is it an EFI 6cyl or a carbie? if its carbie and its original it will have nothing in the dizzy. With the Blue smoke coming through the rocker cover i would suggest it has scored the cylinders and stuffed the rings because thats normally what you see in with extremely bad blow by.
    Do a compression test and inspect your sparkplugs for fouling, does it blow any smoke out the tail pipe? Or make any ticking noises ect?
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The rings are gone. When a motor gets too hot the pistons expand enough to seize into the bore walls and the rings will loose their tension. If you are lucky you might get away with a hone and new rings. If it got really hot it will need a rebore and new pistons and rings. Its a good idea to replace the big end bearings when you have the engine apart. They arent very expensive.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Mine got redhot, had smoke coming out the rocker cover, wouldnt go above 80 without pinging like a bitch.
    This was the result:
    Put a hole right through No.2
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    ari666's Avatar
    1966 impala
    Mar 2009
    Jul 2010
    adlaide
    looks bad its had the dissy replaced with a fuel inject dizzy think time to rebuild her
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by SabbathSS View Post
    looks to me like you may have had a phillips head screw bouncing around in there too soz for "pic quoting" but what are the circles on the left side of the piston?
    Sabbath''s Avatar
    Jul 2006
    NFI, neither did anybody at work. Nothing in the cylinder when i took the head off, bore was unscratched/marked, nothing in the sump either. It's a fkn mystery.
    ari666's Avatar
    1966 impala
    Mar 2009
    if you look closely at the impression you can see a little X inside each circle. ill bet a phillips screw was in there at some stage. you can see it getting squished each time cos the X gets larger and larger
    VH SL/E 5.0
    Nov 2009
    How does a phillips head screw get into a cylinder?
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
  16. #16
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Could be one of those ones with a swapable end and the little end peice fell down when tightening the carbie screws with the air cleaner off.
  1. Replies: 74
    Last Post: 23-01-2012, 08:13 AM
  2. Dieing in trafic...
    By Afterlight in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2009, 09:47 AM
  3. Sick, sick dirty bastards
    By DannyboyDS in forum The Pub
    Last Post: 02-03-2009, 07:50 PM
  4. vl dieing wen it feels like it
    By vl project in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-01-2007, 07:39 PM
