Results 1 to 13 of 13
Thread: Altinator
    efi 202 torana, vk project car!
    Mar 2010
    mount gambier sa!
    Default Altinator
    Hey how do I know if the altinator is hooked up and charging the battery? It's all hooked up but I wanna be certain it's workin before we head off!
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    If the ignition warning lamp stays on after the engine has been started and run at approx 1000rpm carry out the followingtl test and precautions;
    1. Stop the engine, do not open cuircit any parts of the charging circuit whist engine is running.
    2. Check cindition and adjustment of fan belt
    3. Clean battery terminals, tighten all electrical connections, check the wiring for shorts to earth and/or bridged cuircuts and make sure battery is fully charged.
    4. Start engine and allow to run until normal operating temp is reached
    5. Stop engine and disconnect neg terminal.
    6. Remove nut and washer from alternator output terminal and disconnect alternator output lead
    7. Connect one lead of a 60-0-60 ammeter to the alternator output terminal and the other lead of the ammiter to the lead removed from output terminal.
    8. Reconnect battery negative terminal and connect a 0-20 voltmeter across the terminals.
    9. Switch on all lamps and allow them to burn for approx 5min to reduce the charge of the battery and apply a load to the cuircuit.
    10. Start engine and gradually increase the engine speed to approx 2500rpm the reading on the ammiter should be approx 75% of the rated output of the altinator.
    ((11) switch off all lamps and run engine at 1500-2000rpm until the indicated charge is below 10amps. The volt meter should Now read between 12.5-14.7 volts.)
    -gregories service manual #222 page 165-166
    Hope it helps I just typed it out of a book.
    And I'm using my phone so my hands hurt
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    VB SL/E
    Dec 2008
    Do you have a volt meter, just connect it up to the battery with the motor off,
    a good battery around 12V then start it up should jump to 13V plus,
    if the volts rise the alternator is working, if the volts stay the same and start to drop as the motor is running then the alt/reg is doing nothing.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    LMAO!!! talk about overcomplicate things.
    1. start engin
    2. disconnect earth lead
    is the engine still running?
    no= alternator is NOT working
    yes= alternator IS working
    if the engine continues to run with the earth lead DC, and to check if the alternator is working well, turn on all your electricals, i.e. heater, lights hazards, foot on the brake, radio, cig lighter. all that stuff MAY cause your engine to die, if it does, reconnect the earth lead, start her up again, and this time turn all that stuff on while holding the revs at around 1800rpm (which is roughly the point where the alternator will 'turn on')
    if its working the engine should continue to run with all the electrics on.
    vk.jonno's Avatar
    Nov 2009
    south east
    Well maybe u should re-write the gregories manual then so I don't feel like a fool
    Mar 2010
    mount gambier sa!
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its the easiest way to kill an alternator if its not allready just use a multimeter on the battery terminals and check voltage
    ari666's Avatar
    1966 impala
    Mar 2009
    VB SL/E
    Dec 2008
    You will overload the electrical system by disconnecting the earth while the motor is running, you should NEVER disconnect the earth while the motor is running, especially with an ECU, the charging system is meant to have a load on it, that load is the battery, if there is no battery where do you think the system will find earth to charge?
    VB SL/E
    Dec 2008
    Quote Originally Posted by delcowizzid View Post
    Hmm yeah would love to hear where this one come from lol.
    ari666's Avatar
    1966 impala
    Mar 2009
    ???? the alternator doesnt just create +V
    you disconnect the battery and it will find earth from the alternator...
    the battery does absolutely F'k all for the running of your car. at the best of times a battery fully charged MAY go a little over 12V, but when your car is running it should be up around the 14.5V mark. the battery is only there to look pretty and let you start her up in the morning. after that the alternator does everything.
    disconnecting the battery while it is running is no worse that taking a jumper lead off after jump starting your car with a flat battery.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it burns out the diodes in alternators but thats the easy part to fix LOL
    never let anyone dissconnect your battery with car running
    The moment he disconnects either lead from your battery, it's entirely possible he caused thousands of dollars in damage. Here's why...
    Your battery does more than just yield electricity. It also shorts AC, spikes and transients to ground. Removing the battery from the circuit allows those spikes and transients to travel around, endangering every semiconductor circuit in your car. The ECU, the speed sensitive steering, the memory seat adjustments, the cruise control, and even the car's stereo.
    Even if your computers and stereo remain intact, in a great many cases removing the battery burns out the diodes in the alternator, necessitating a new alternator. If disconnecting the battery interferes with the voltage regulator's control voltage input, it's even possible for the alternator to put out hundreds of volts, frying everything.
    Even the initial premise was wrong. If you disconnect the battery and the car conks out, you don't know if it conked out due to insufficient alternator current, or whether the resulting transients caused your ECU (the car's computer, which controls fuel mixture, timing, and much more) to spit out bad data, shutting down the car.
    Nobody should EVER run your engine without a battery.
    And yet when you tell them not to, they'll roll their eyes. "I'm a professional. I do this every day. It's fine!" They'll sound so authoritative. So commanding. So intimidating. But they're wrong.
    The problem, of course, is that disconnecting the battery doesn't always damage something. It does it only sometimes. Less experienced jump start professionals and automotive technicians figure if they got away with it a few times, it must be OK
    ari666's Avatar
    1966 impala
    Mar 2009
    well VKtorana there you have your two opinions:
    1. disconnecting the battery will burn everything in your car and wont tell you if the alternator is not working
    2. disconnecting the battery will tell you if your alternator is working
    i was gonna argue, but comments like "in a great many cases removing the battery burns out the diodes in the alternator" has just flabbergasted me. and decided its not worth the effort.
  1. gen 3 altinator melting,,,,,help
    By gen3calias in forum Electrical Wiring / Questions
    Last Post: 18-09-2009, 11:37 PM
  2. Altinator question
    By neil001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 12:46 AM
