Results 1 to 6 of 6
Thread: vs seats
    vb sl
    Aug 2010
    mortlake
    Default vs seats
    just wondering iv had a bit of a look and i reckon the saets out of a vs would fit in the vb front and back has any one already done this how did turn out
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Need longer bolts
    And I think u need to do new back hole from memory
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    The back seats won't fit as they are to wide but i think you change the rails over on the front seats.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by pjdm1980 View Post
    Correct this has been covered a number of times
    Either buy a set of 85 VK seat rails or buy the outter rails for vn-vs and pair them up so the outter D/S and outter P/S rails will make a pair and become one pair. Fron memory using the vn-vs rails the seat will actually sit about 10mm lower in the car
    cheers
    Scott
    weston is offline Holden VH V6 Commodore
    VH Commodore
    Apr 2009
    Ive done this in a VH, i got front and back seats from a VS Berlina and fitted them in buy drilling a new hole in the inside rail at the front of both seats and made a spacer between the floor and rail. Otherwise the holes line up nicely, (may not be totally legal but was able to cover it up with the carpet) and for the back seat yes it is wider than VB -L but with a little cutting here and there on the wire frame i made the lower half fit.
    Now when the rear doors are closed the side of the lower half sort o spring inward without a hassle, as for the top half i once again played with the wire frame a little and drilled hole in the back wall and bolted the three bits into place.
    vb sl
    Aug 2010
    mortlake
    got some pics off the back
  1. Having a problem with my seats after fitting vy seats to my vt.
    By adamrollo9 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2010, 01:51 PM
  2. VIC Sports bucket seats (like racing seats)
    By ucwepn in forum Parts And Other Items For Sale
    Last Post: 23-12-2005, 03:17 PM
