Results 1 to 9 of 9
Thread: what can i fit on my vh from a vl
    VH SL 202
    Feb 2010
    Default what can i fit on my vh from a vl
    hey
    im getting a vl soon one of mates dads what i want to know is what parts under the car would fit in my vh (eg.. diff, brakes, interior ) can someone tell me what would fit and im not trying to make my vh look like a vl i just want to give it a freshen up with diffrent parts
    Vy 2 SS
    Jun 2009
    Mate the diff,suspention,brakes will fit as for trim the back seat will fit the front passenger side seat needs spacers as the Vl had a raised hump in the floor to clear the cat.Drivers seat fits no worries.Dash fits but will need a few brackets bent up to hold it in place.Not sure about using the Vh heater with the Vl dash as i removed my heater box.
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    VH SLE injected 5L
    Oct 2008
    VH SL 202
    Feb 2010
    calais24/7's Avatar
    Jul 2009
    Mirrors are the same but the tailights are differant so i think the garnish would be a bit differant
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Pretty much everything on the body and interior side of things is interchangeable except boot lid, front end panels, trim around the rear quarter windows If you change the dash I think you need to use the VL front window which is glued in, and the heater box and bolt up differently, you need to cut a new hole and wired differently.
    Mechanically if it's a six you can change the whole drive line (including the K frame, fuel tank Power steer rack) over but a lot of work for not much value, brakes are the same unless they are turbo so they'll fit but are bigger.
    Hope that help.
    VH SL 202
    Feb 2010
    thanks guys im thinking of using the rear plastic peice from between both taillights the peice that says *commodore* on it ill make it fit haha
    VB SL/E
    Dec 2008
    Diff will bolt in but I believe it is different width so you may need the wheels to go with it to gain the correct offset.
    Also tailshaft bolts up different so you will need to swap the rear half with the VH one.
