i recently replaced my vacum gauge for a tacho and i cant work out how to connect it would i have to do the wiring myself and i also need to know what pins are what
On a VK top is earth, middle is signal/negative terminal on coil and bottom is positive from ignition.
Originally Posted by VK SL 202 On a VK top is earth, middle is signal/negative terminal on coil and bottom is positive from ignition. thanks mate ill try wirering it up myslef
Forum Rules
