Results 1 to 6 of 6
Thread: VH Cigarette lighter not working but...
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Question VH Cigarette lighter not working but...
    Hello again fellow JCians.
    My VH cigarette lighter is not working when i plug anything into it BUT im running my UHF and some lights of the cigarette lighter's cables with out any problems. I also tested the connections with a light (light pen???) and it is getting power.
    So what could it be? maybe something else not plugged in? maybe i don't have it put together correctly?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    have a look at the tip of the cig lighter. ill bet its all rusty in there. if the coil is broken it wont work. if everything else you plug into the cig lighter cup (thingie) works ok then its def the lighter itself thats at fault.
    edit* the coil i am refering to is the pic on the right:
    The Blues Mobile
    Dec 2008
    Western Sydney
    Silly me. I mean the cup? (the actual place you plug things into) not the actual lighter is not working. So when i plug something in it gets no power.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    So is your CB and that working off the cable before the lighter?
    It might be shitty wiring to the 'cup', or even a faulty 'cup'
    My one is ####ed as well, it is probably just age on the socket
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    ari666's Avatar
    1966 impala
    Mar 2009
    check the earth to it. its either a plug that plugs into the side or a ring that screws around it. if thats ok check the power wire in the very back. if thats ok, then i dunno
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    also try giving the positive "dot" right in the middle of the cup, a quick scrape to bring out a bit of fresh metal for clean contact
  1. cigarette lighter/ power acc not working
    By surfdog in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-09-2010, 09:24 PM
  2. VS 12V cigarette lighter not working (no voltage)
    By catalyst55 in forum Electrical Wiring / Questions
    Last Post: 10-06-2006, 09:36 PM
  3. Cigarette lighter not working
    By killuminati in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 05:44 PM
  4. Cigarette Lighter working
    By Denno in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-02-2006, 10:59 PM
  5. cigarette lighter not working
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-08-2005, 08:43 PM
