Are they located in the doors themselves?
My drivers side rear window decided today that it doesnt want to go up. doesnt work with either the front or back switch. No sounds or anything when switch is used. All other windows work fine.
Any ideas?
Don't they all work off the same relay, I'd say probably a motor more likely. I think vk were under the dash still?
year im going to have a look tomorrow, i havent played aroudn with vk power windows before. might even be as simple as a fuse (if they have a fuse for each door), but then again a fuse blows for a reason. just weird how it worked perfect everyday and worked perfect winding down but then wouldnt go up
