There will be extra cost in getting either a V8 driveshaft or modifying the one you have to cater for the larger rear uni. As mentioned above the U bolts are also longer to suit the larger yoke (uni cup size is the same), if the diff doesn't come with them you'll need to get a couple. l Otherwise bolt-in.
and dont let those silly bolts fool ya. cheapest i could find them was 15 bucks EACH!!! i know its not much, but for a pissing little tiny bolt is a lot. plus they are balanced so dont think you can grap a couple of zinc ones from the hardware store either![]()
these them what ye be needin'
Universal joint U BOLTS Holden 1 Ton - eBay Universal Joints, Driveshafts, Transmission, Car, Truck Parts, Cars, Bikes, Boats. (end time 09-Oct-10 01:25:14 AEDST)
30 bucks plus postage, bloody thieves. the yolk on the V8 diff is thicker so it needs the longer bolts.
and they snap...
so be careful
should stick a ford 9inch in. that will solve all problems and ou never have to touch it again :P
dirt track cowboys
