Results 1 to 11 of 11
Thread: VB,VC,VH,VK Headlight relay upgrade results?
    VH Sl wagon and vr executive t5
    Dec 2009
    Default VB,VC,VH,VK Headlight relay upgrade results?
    hey guys im just curious as to whether anyone has put relays on the early girl so the headlights receive full voltage and so i can then later on put better bulbbs in with out risking melting the loom. now i know how to wire it in etc just use the origninal wiring to the headlights to switch the relay etc no problems there ..
    i just did some quick test the other day and found that there was nearly a 2 volt drop at the headlight . so i quickly just made a jump wire to the battery and i had a slightly brighter lights so thats a good start
    has any one else done it and wat bulbs would you reccomend if i was to upgrade i have heard good things about phillips range
    i may do a "how to" on it depending on feed back here
    and now have to get rid of my 19ssv's off my wagon ;-( so i am looking for some nice 18's or 17's willing to swap my SSV's for a clean set of wheels with cash ajustment because me being 18 and stubborn i wanted to keep them but after a look at how much work there really was in mini tubbing it i have decided against it
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    yeah had relays on my VK for years after I melted a headlight switch, fuse rail and headlight wiring with high wattage globes.
    The resistance is what kills the connectors and wiring, you will notice a huge difference in your lights when you do it.
    USE STANDARD wattage bulbs else you will melt wiring etc and possibly cause an engine bay fire.
    I got a hold of the original wiring harness pins and made heavy duty headlight harnesses and found the wiring harnesses held up but the plug sockets melted so best to stick tot he standed globes
    scott
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    NICE do replacement H4 globe sockets if ya ever need replacements. I'm sure they'd have to be made of a better material then those of 30 years ago.
    Part number is TS286.
    http://www.niceproducts.com.au/downl...sible_link.pdf
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    I put standard vn-vs type square headlamp relays relays in the space behind the lefthand strut tower...used the bases that they normally have and made up a bit of a bracket so they all fit together and ran a larger red 12v cable that teed off the large cable that fed the starter cable from the battery.....worked well and thats where I put all the relays and fuses for the efi that I later installed...no voltage drop...looks neat and is easy to get at and saves the headlight switch and those dodgy fuse bases inside the cabin from melting.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    this: HID XENON Conversion Slim KIT H7 H1 H4 H3 6000K 8000K - eBay Headlights, Lights, Indicators, Car Parts, Accessories, Cars, Bikes, Boats. (end time 30-Sep-10 19:40:24 AEST)
    is a 35W globe. doubt you will have any wiring issue at all if you direct swap them with your H4's, the only problem is they run really hot so may have issues with thesurround of your headlamps, but since they have glass lenses im sure it'll be fine.
    plus these are OOODLES brighter than a halogen.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    When I did my headlight harnesses i went to a local panel beater i know and grabbed a couple of old headlight harnesses and used the plugs off them with new wire, pins and sockets
    cheers
    Scott
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    My VH has this done, double relay with it's own fuses. just use some of those +50 type blobes. the other problem is that the reflectors in the headlight become dull which effects light output as well.
    have also done the same with the starter motor circuit to save the ignition switch
    Body by Holden, Soul by Brock
    the Legend will live forever
    VH SS
    May 2009
    Toowoomba, Qld
    I've hooked up a headlight relay and bypassed the standard crap ceramic fuse (which is always a source of problems) and fit up a blade type fuse.
    Results were quite remarkable. Headlights now work as well as any new car, and I'm only using standard H4 globes
    VK 4.9L Calais straight LPG
    Sep 2010
    The Central Coast
    I wacked some 55w HID's bi's in mine and would not go back to halogen, 5 times brighter with the big VK reflector.
    Does not run hot at all.
    1983 sl vh commodore,3.3cyl
    Oct 2010
    Quote Originally Posted by Darren_L View Post
    hi darren,im only new on site,and was wondering if you might be able to send me the wiring setup you done on your car for the above?in laymans terms. my car is a 1983 6cyl vh sl.thanking you. tyrone.
    Aug 2006
    ive done this before on my kingswood worked well im in the process of doing this at the moment will post the pricture's when im done
  1. HID Headlight upgrade kits
    By Ace_VP in forum Electrical Wiring / Questions
    Last Post: 25-06-2010, 02:56 AM
  2. Dyno Results, Drag Results, Circuit Results, comparo
    By impulsesv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-09-2008, 04:58 PM
  3. Headlight upgrade
    By Outlaw Torn in forum Electrical Wiring / Questions
    Last Post: 26-07-2006, 02:46 AM
  4. Foggies on the headlight relay
    By VXWAGMAN in forum Electrical Wiring / Questions
    Last Post: 27-02-2006, 04:10 PM
  5. VT headlight upgrade
    By scojohara in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2006, 09:50 AM
