Results 1 to 6 of 6
Thread: pcv into carby
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default pcv into carby
    My 750 Holley only has one large vacuum port on it, which I'd wanna use for the brake booster. That creates the problem of now having no where for the pcv to go. Can I just put a t-piece in the vacuum line going to the brake booster or would that effect the brakes?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    brake booster should be run off manifold vac, not off the carby. im not sure how the PCV would affect the consistancy of the vacuum going to your booster. cos that little valve opens and closes quite a lot.
    personally i would just hook the booster up to manifold vac, where it is supposed to be. what manifold you using?
    DANNY8's Avatar
    Apr 2004
    It's a procomp manifold. It has a bit along the back driver side runner which looks like it could be drilled out and tapped.....but obviously a bit hard now it's on the motor and don't really wanna pull it off.
    Might just have to use a t-piece in the brake hose and just see how it goes. I guess another option is to use a small spacer under the carby and put a fitting in that.
    Ya can just see it in this pic.
    ari666's Avatar
    1966 impala
    Mar 2009
    hmmm, i really dont know what affect the pcv will have on the booster. think it may drop the vac too much, but as ive never done it i cant say for sure... i suppose its worth a go hey?
    you could always ditch the PCV and go with a regular breather? im assuming this thing isnt epa friendly anyway?
    DANNY8's Avatar
    Apr 2004
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    you might be able to port the PCV valve intot he air cleaner assembly that will sort out vacume might make the carbie messy if you get blow by at some stage
    scott
  1. Carby V6?
    By vh-holden in forum V6 Development And Modification
    Last Post: 09-11-2011, 07:59 PM
  2. swapping Jets from starfire carby to 202 carby
    By RippleEphex in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-06-2010, 02:01 PM
  3. HELP!!! EFI Or Carby????
    By MY_84_VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-04-2010, 07:24 PM
  4. Carby for VC
    By originalvc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2007, 02:07 PM
  5. Carby 4 vs 6
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2006, 11:27 PM
