Results 1 to 4 of 4
Thread: vh indercator stalk
    VH SL 202
    Feb 2010
    Default vh indercator stalk
    hey guys im trying to get my indicator stalk out... mine stuffed to the max i cant use the right signal lol and my highs keep coming on every time i touch it it has so much movement you could almost use it as a colom shift lol but i kind of cracked the shiiiiiits and pulled on it and it came off and now the wires are showing lol so im not sure what to do i can get a new indicator stalk so yeh
    VH SLE, 1968 Firebird
    May 2010
    Quote Originally Posted by TY318 View Post
    You have to take the steering wheel off, there is a screw holding it on which can only be accessed with it off and you'll need a wheel puller to get the wheel off.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Also to get the wiring harness attached to the stalk out, ya need to remove the other mechanism around the column as well, which the stalk attaches to. To remove it there's 3 screws which ya can get to with the indicator stalk either up or down (otherwise the mechanism covers the screws), can't remember which, after those 3 screws are out, undo the hazard light button and she'll pull out enuf for the stalk connector to come through. You'll have to remove the panel under the steering column to undo the stalk connector. 3 philips head screws which are removed from underneath, then that will come off and should reveal the wiring.
    NICE products do repro indicator stalks, I bought one the other week through Repco. NBS70B is for a black one, for part numbers of other colour stalks, check out this PDF file.
    http://www.niceproducts.com.au/catal...Column/GMH.pdf
    ABW do steering wheel pullers. Part number is ABW70382 (or just 70382). They're available through Repco. Also available from the site below.
    70382 Steering Wheel Puller - ABW Tools - Online Toolshop
    VH SL 202
    Feb 2010
    wow didnt know u had to use a steering wheel puller i usually try and rip mine off haha sometimes it worked
  1. vh indercator stalk
    By TY318 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-08-2010, 11:58 AM
  2. indicator stalk
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2007, 07:34 PM
  3. Indicator stalk VT
    By Nod in forum Electrical Wiring / Questions
    Last Post: 03-03-2007, 11:14 PM
  4. VX Indicator Stalk
    By Melchior3 in forum Swap / Wanted to Buy / Trade
    Last Post: 08-02-2007, 04:51 PM
  5. indicator stalk
    By junglepatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2004, 09:34 AM
