Hi all I am thinking of changing the slip in yoke that goes into the back of my gearbox to one that has a larger universal joint.
Does anyone know if there is another borgwarner gearbox that has the same size rear spline but a larger universal joint than the holden 6 one.
Am thinking maybe a 5 speed out of a VN may fit but dont have one to try or maybe a ford tail shaft will slide in with a v8 sized uni.
Any one know?
I can tell you tomorrow if a vn one fits cause i have a Vh borgy shaft in the shed and a t5 with shaft as well.
Thanx. Will be interested to know. I am swapping out the small salsbury for a borgwarner diff and have found the front half of the VK shaft doesnt fit the VL rear section like I hoped it would. So If I am going to need a custom tailshaft I may as well go to a bigger front uni as the VL CV and rear uni are all the bigger size already.
