Results 1 to 12 of 12
Thread: VK stage 3 shift kit advice
    VK berlina commodore
    Sep 2010
    Kempsey
    Default VK stage 3 shift kit advice
    Hey guys this is my first post on here
    I couldn't find this exact question anywhere else so here goes
    I'm wanting as much info on weather any brand of stage 3 shift kit can be put in a stock VK auto and how to do it??
    Thanks
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    VK V6
    Mar 2010
    NZ
    I don't know if anything has changed but it didn't use to be possible to get off the shelf kits for Trimatics. The same basic stuff is still applicable though and any decent trans rebuilder will be able to sort it for you. Stage 1/2/3/whatever doesn't mean anything except to a certain brand/supplier though, so you will need to be more specific on your requirements.
    Sep 2010
    Kempsey
    ari666's Avatar
    1966 impala
    Mar 2009
    absolutely. although there is no such thing as "a kit" as far as im aware of. a mate of mine build a couple of 6 cylinder full manual trimatics which were on a couple of TOUGH EH's but he had to source all the parts out individually. unless you know what you are doing, then take it to a transmission center.
    ve sv6
    Aug 2010
    vn
    Nov 2009
    noble park
    Sep 2010
    Kempsey
    Well I dnt know to much bout macheniques but I jst wanna make my auto go way harder any ideas?
    ve sv6
    Aug 2010
    if you can find a decent auto guy he can open up the valve body to make it shift a bit firmer and put some decent clutches in it. is it a trimatic or turbo?
    the lightning
    Jun 2005
    under the Southern Cross
    Phil Soderstrom makes the parts required to beef up a trimatic.... they can be a good trans for anything up to 450hp with the right mods, after that you gotta start spending serious money and get various parts hardened / heat treated ect.
    Tradematics in Geelong built mine years ago and its withstood years of punishment.
    you'd be looking at a full manual valvebody, extra clutchpacks in top gear, chrome moly servo piston, boosting the oil pressure in the trans and running an external trans cooler and bypassing the one in the radiator and running a decent converter if the engine has a cam.
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
    the lightning
    Jun 2005
    some people prefer to drive their cars. its a personal choice thing, and an easy way of shaving a little bit of time off at the drags, a must on a strip car, but handy on a street car that sees the dragstrip aswell.
    ari666's Avatar
    1966 impala
    Mar 2009
    meh, my shift kit does fine for changes, guaranteed it breaks out 2nd and 3rd at high rpm, and if its wet... well you just dont drive hard when its wet. i find it difficult to believe a manual kit would be any better, especially if you upgrade your clutches when you do a normal kit.
    but yeah, each to their own, dunno why you wouldnt just fit a manual box...
  1. Stage 2 shift kit
    By W8INL9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2010, 01:58 PM
  2. Stage 2 or Stage 3 shift kit?.....can someone just quickly explain
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2009, 03:25 AM
  3. stage 2 shift???
    By vn4play in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2008, 06:54 PM
  4. stage 2 shift kit VR
    By VZHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2007, 05:55 PM
  5. Stage 2 shift kit
    By Col74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2007, 08:28 PM
