Results 1 to 12 of 12
Thread: VH 253 conversion.... is there anything to it?
    vh commodore sl vacationer
    Aug 2009
    Question VH 253 conversion.... is there anything to it?
    Hey guys.
    So i have a 82 VH wago with a Blue 202. currently running duel fuel and has an aftermarket powersteering kit on it.
    ive recently aquired a 253 with a 4 slotter man, starter motor, alternator, engine mounts, dizzy, holden sump and pick up, strongberg carb, Lukey extractors, mild cam. Plus a few other bits an peices.
    I was just wondering if there is anything i need to know about before i make this conversion.... im doing it myself im pre sure it shoud be straight forward... the wago is a SL not an SLX. cheers
    VB SL/E
    Dec 2008
    You will need a V8 P/S bracket and even then the pump may not bolt to it so maybe a pump too, then your hoses may not reach if they are different length.
    Also you need accelerator cable, radiator and hoses and clutch/brake pedal plus clutch cable.
    LPG should not be to hard to modify the base to fit if the hoses are long enough but it maybe a bit lean if your tune is spot on at the moment.
    Aug 2009
    ahh righto... ye i was told im gonna have to get brackets for the P/S and something else. and im ditching the gas all together... im an apprentice mechanic and ive seen first hand the damage gas does. im also gonna put a better pump for the P/S and im buying a new radiator, also was gonna ditch the fan bolted to the motor for a set of thermo's. and maybe fit electronic ignition.
    Aug 2009
    im more concerned about the tailshaft and diff. cos its got the Trimatic auto in it now. ive been told the aussie 4 speed and the gates will line up but im not 100% sure bout that.
    VB SL/E
    Dec 2008
    VB SL/E
    Dec 2008
    Mmmmmm do I?
    You may also need to extend/replace some of the wiring as some will not reach on the motor loom, gear box reverse switch should reach and also delete the inhibitor on the stick for the auto.
    VH SS
    May 2009
    Toowoomba, Qld
    I did a V8 manual swap into my previous 6cyl VH auto. It's not very difficult
    if you can, go to the wrecker and pick up an engine harness off a VH V8.
    It just unplugs from the firewall, and will plug straight in where your 6cyl harness plugs.
    Makes the wiring a lot tidier and easier.
    Also if your wagon is an auto, then you'll need to get yourself a manual pedal box, preferrably from a V8 manual car (6cyl & V8 clutch pedal & box differ slightly)
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    Gday At this moment I'm doing the same thing, just to make sure that your brakes and suspension can handle the V8 mate, you might want to up grade your diff too.Tail shaft frt half has to be 100mm longer than 6's. 6's are to short. I hope this help you mate, Cheers Jason
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by vkwalks39 View Post
    just to make sure that your brakes can handle the V8 mate,
    lol, OP is talking about a 253... i think the brakes will be fine
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Meh do the brakes anyway.
    Those old brakes that were on everything from VB to VS suck major balls.
    Aug 2009
    sorry fellers had no net for a while there. yeh cheers for all the help. about that shaft... can i put some sort of spacer or something in there or is it worth just replacing. and i plan to upgrade the brakes and suspension... she floats all over the road. haha. and i plan to upgrade the diff when i blow it..... sooo soonish
    vkwalks39's Avatar
    Sep 2007
    Stawell Vic
    G'day, just go out and buy yourself a v8 tailshaft. It's easy than put spacers mate. Get yourself a warmer camshaft, like .486" lift from crow cams, and set of anti pump ups lifters too. Cheers Jason
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
  1. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
