Results 1 to 5 of 5
Thread: few questions
    vp wagon
    Sep 2009
    Default few questions
    hey guys..
    i have a vb with 253 and aussie 4 speed.. diff is ####ed..
    im aware that vb up to vk fit and i can use a borgy as long as i change the tailshaft..
    but... does a vl diff fit?
    and can you use a 6 cylinder diff behind it.. obviously mounts are same but how much difference in ratio? are the yokes the same? are the 6 cylinder diffs weaker?
    Also it was originally auto and has had manual conversion by previous owner but when i look in the car at the gear shifter it sits towards the drivers side of the hole in the floor by quiet alot..
    it actually just touches the side when i go to 3rd and 4th gear.. is this normal? if not what could be the cause? incorrect gearbox mount? mount wrong way round?
    cheers in advance for any assistance i recieve
    90 mazda 323
    Oct 2010
    perth nor and lovin it
    yeah mate the vl diff would fit fine whn i had a vk 5litre manual it was running with a 2.6 ratio or somthing like that so then me and my bro bought a vl 6 diff place it straight in and of course we got a minispool put in to and it was runinng better.the good thing about the vl diff is its got 3.45 gear ratio and that good enough for the aussie 4 cos we only cud reach 160km/h with 4th gear thats the only down side with the vl diff.plus the vl diff has a shorter axle so that means you can run fatties on the back.
    vp wagon
    Sep 2009
    sweet sounds good. yeh topend and fuel costs dont really bother me. Its not an everyday driver. how do i go about correcting the speedo?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by ari666 View Post
    isnt the VL diff wider axle to axle?
    certainly is not by much though fits nicely in my VK
    Speedo is corrected by changing your speedo drive gear on the end of the speedo cable, i have sheets on my site plus a good stock of speedo gears
    scott
  1. V6 Questions
    By VN_S2 Boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2008, 10:22 AM
  2. 2 questions.
    By RhysMegeese in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 01:16 PM
  3. LPG Questions
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2008, 09:10 PM
  4. VN SS questions
    By baz1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2006, 10:08 PM
  5. vp ss questions
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2006, 10:57 AM
